Bigger Rear brakes on an 89 accord (could work with CRX also)
Discussion in 'Wheels / Suspension / Tires / Brakes' started by Legend_master, Dec 20, 2006.
  1. Legend_master
    Legend_master Junior Member
    Ok hondaswapers people I have been working on this project for awhile now. So what I have figured out is that I can run 1989 Acura Legend Rear calipers on the Accord SE-i hub. These calipers are spaced out more to allow for a 10.2" rotor on the legend application. I put some EP3 03 Civic Si rotors on the hub with the legend calipers and I ended up with 1/2" an space between the rotor and the inside of the caliper (pictures at the bottom of the post). So I plan on picking up some power slot 11" rotors to run with this setup, my dilemma is that I will end up with a pad that doesnt cover the whole rotor. So if anybody out there has an idea of a longer pad that I could use to extend all the way across the rotor that would really help. As for the CRX in the title, the rear CRX brakes are almost identical to the accord of these years. This means this mod would work for you CRX guys.
    1989 Legend caliper/bracket, EP3 civic rotor, 89 Legend Pads
    The legend caliper also has a much larger psiton then the accord/CRX one does(dont worry about the yellow writing in the picture, I used it for a DIY).
    Here is a comparison between the different Legend pads, none of them extend down far enough and the NSX is completely different.
    G3 Legend (USA RL)
    (88.9 x 47.4 x 15.4) 11" rotors
    G2 Legend 11" rotors
    G1 Legend 10.3" rotors
    (88.9mm x 47.4mm x 14.6mm)
    and for all the old school accord haters I have done a number of mods to this ride such as 11" front rotors with ITR calipers, and LS/v swap, and full suspension so :p .
  2. E_SolSi
    holy shit!!
    excelent job
    props to ya :worthy:
  3. Legend_master
    Its not done yet, but thanks for the props I have spent ALOT of time on this project. I hope someone can help with the pad issues.
  4. phunky.buddha
    Dallas / Fort Worth, TX
    You don't actually need to cover the entire rotor surface with the pad- just make sure that your pad doesn't hang off the edge anywhere.
  5. Legend_master
    I would hate to waist that much of the rotor and I would gain a large amount of stopping power from it. Also In case anybody wants to know, you can fit Legend Calipers onto the EP3 civic Caliper bracket.
  6. phunky.buddha
    This is what I had on the front of my Civic:
    Back:
    I had no problems in the rear. It was perfectly balanced. If you think about it, you just need enough pad area to not hotspot your rotors. More area won't give you more stopping power- you're still applying the same amount of force. More area IS good for heat absorption and tolerance, but it's not key to better braking. Take this point into consideration too- the amount of leverage you have on your hub will go down if you use a pad that extends deeper into the center of the rotor. Your lever arm goes from the center of the disc to the center of the pad, so a good pad that doesn't cover the entire face of the disc but placed as far to the edge as possible will have more mechanical advantage compared to a pad whose center sits farther in.
    Got it?
  7. Legend_master
    ok I see, so I will run some factory size EBC pads with the 11" powerslot rotor. Thanks for the help and BTW your front setup is very clean.
  8. phunky.buddha
    Thanks! That setup is dead now, but you get the idea. Good luck with yours.
  9. D See 2
    D See 2 Senior Member
    Baltimore, MD
    Shouldn't the same amount of force exerted over a larger surface area yield more stopping power?
  10. phunky.buddha
    :no:
    You're still exerting the same amount of force- just over a larger area. You have the potential to have more braking power because you have more pad area to spread things out over, but that's usually taken care of with piston sizes, not pad size.
    Larger pads may give you more fade resistance, but that and braking power are mutually exclusive.
  11. Legend_master
    Thanks for the help Calesta, but look at how well the Legend caliper matched up with the 11" 99 civic power slot rotors. It turned out that the pad covered the whole rotor anyway.
  12. phunky.buddha
    Wow. That's a great fit! I don't think you're actually covering any more area than my setup though. Compare the width of the rotor surface- my rears were 11 inches also. Yours is thinner, mine thicker- but the pad contact area looks about the same.
  13. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Looks like overkill for a CRX, those rears are bigger than my fronts! I'm guessing that setup won't fit under 14s will it?
    I have 10.3" in the front btw.
  14. Legend_master
    yep, it is identical to any other civic, accord, integra setup on the pad surface, but the Legend Piston is much larger the any of those. So I am hoping for better breaking performance.
    It is actually for an 86 accord hatch, but I will be runnning 11" front and 11" rear. The whole reason behind this is to figure out whar actually works for this car.
  15. GSRCRXsi
    MD
    hmm it would be nice to have a 10.2" setup for the rear. i think a 11" front and 10.2" rear would be perfect.
  16. Legend_master
    Im not sure how to go about that, the Legend caliper is to big and the CRX, SE-i, ETC... are to small.
  17. phunky.buddha
    You can still run an 11" in the rear- just run an adjustable prop valve so you can tune your braking force just right.
  18. K2e2vin
    Raleigh, NC
    I was referring to the title which says will work with CRX. For a Accord hatch, it should work great since they're much heavier than CRXs(I was going to get one but found a Civic HB instead).
  19. Legend_master
    Ok I see, I figured I would let people know since I am sure there is someone with a CRX out there that wants to Overkill on the brakes lol . The spacing on the CRX MIGHT be differnt and if it was closer to the hub then you could bolt on the ep3 rotors and legend calipers.
