Bike carb'd dual cam zc build
Discussion in 'Engine Building' started by dilbeckskate, Jun 16, 2016.
  1. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    Ok guys I picked up a dual cam zc that has been sitting and im going to rebuild it to swap into the 79 , im going to run it on kein bike carbs and I would like to go high compresion (stock 9:5:1) and while im in there would you guys bore over ? And im also planning on getting a nice set of H beam rods , anyways here for imput and pics to come
  2. Matts96HB
    Matts96HB . Moderator VIP
    I'd leave the bore if it were me. I just don't see enough benefit for it to really make sense.
    I like the bump in compression and going with a good set of pistons and rods. If you can get the carb setup running smoothly, this will be neat!
  3. dilbeckskate
    Kennesaw Ga
    I'm going to build the bottom and now in case it later it isn't enough power and I go EFI and or power adder and I don't have to dig back into it I think I'm going to go with a 76 millimeter bore p29 Pistons and a nice set of h-beam rods
  4. jlicrx
    jlicrx Senior Member
    Colorado Springs
    how big are those carbs?
  5. dilbeckskate
    Kennesaw Ga
    Im going to use a set of kein carbs off a gsxr 1000 like I did on the 4age , this thread can be deleted im posting all now under the 79 civic thread
