Bitch axle Nut
Discussion in 'General Tech and Maintenance' started by vtecjdm, Jun 6, 2005.
  1. vtecjdm
    vtecjdm Senior Member
    Ok .. this may sound the usual question about how to remove that bitch of an axle nut.
    Indeed it is .. but this time i`m using a twin hammer impacter !!! and still doesn`t wanna get off. :blink:
    I first bent the nut back so the nut could turn .. then used the impact drill.
    Using 90psi on drill ... and turning in reverse ... what the helll ?!?!?! :blink:
    Anyone had this prob ? ... am i doing something wrong or what
  2. pissedoffsol
    drill? get your self an impact gun. a drill probably isn't what you want to use.
  3. 92civicb18b1
    92civicb18b1 The Trisexual
    you need an impact. a drill just doesn't have the torque to break it loose.
  4. 92civicb18b1
    actually, use a 1/2" ratchet and a 3 ft extention.
  5. NoJokE
    NoJokE Senior Member
    Drop the car to the floor. Get a 1/2" breaker bar and a pipe. Proceed to stomp on said pipe......
    And it'll still be a bitch :p
  6. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    Had the same problem with mine. Not even a 1/2" drive impact gun could break it. One die-grinder, propane torch and a whole lot of expletives latter, we got it off.
  7. vtecjdm
    opss excuse me meant i used an impact ... not drill.
    Hmm ... might depend on the actual impacter.
    Torque may be diff from model to model on those impacters ... will try an other one tom.
    But me still think the breaker bar is needed.... we`ll see
  8. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    I kept breaking my 1/2" breaker bars (was putting pipes on it), so I went out and got a 3/4" breaker bar, smacked the nut with a sledgehammer, and jumped on the breaker bar, that got it loose.
  9. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Few ways to do it. If you have airtools, rent a really good impact gun and crank your compressor to 150psi and it should take it off. If not, put the wheel back on, punch out the center cap, lower the car, put the socket on the nut. put the breaker bar parallel to the ground, and slip a heavy duty steel pipe over the breaker bar (longer the better) and with a floor jack, raise the end of the pipe (have someone hold the brakes). If the pipe is 3 ft long, a corner of the car probally weighs about 600+ lbs, so thats 1800ftlbs on that nut. It will break it off
  10. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    When I did mine, we thought it was moving, but no, the car was coming off the ground, so another friend jumped in held the brake and voila, 3/4 drive with a 5ft cheater pipe.
  11. sihatchback_RL
    sihatchback_RL Senior Member
    i just use a 1/2 drive 32mm impact socket with a breaker bar and a huge steel pipe and have my fat cousin ride on it. as soon as he starts to stand on it, pops it right off.
  12. driverunknown
    driverunknown Senior Member
    good idea on the impact socket. I have broken a craftman regular one before. Make sure you have a nice breaker bar, autozone ones have broken on me before also.
  13. EGProject
    Wow, all this work seems a little tiring. Do what I did, and cut the nut off with a die-grinder.
  14. reckedracing
    reckedracing TTIWWOP VIP
    NY
    you could heat the nut with a torch...
    or you could try the ingersol rand 1/2" twin titanium hammer impact gun, that might do it...
    i went out a bought a cheap 3/4 inch socket set, it was only like 50 bucks from places like harborfreighttool.com, etc
    you can have someone hold the brake, or use a GOOD screwdriver in the rotor against the caliper, cheap screwdrivers will break...
    the 3/4 set hasn't let me down yet...
    i broke 2 - 1/2 inch ratchets and the 3/4 set took it right off...
  15. pissedoffsol
    $45 650 ft lbs huskey impact works for me :)
  16. vtecjdm
    Indeed changed the impact to a high power electric one and the nut got off in 5 secs ..! ... however ... <_< ... those 2 tranny mouting bolts didnt wanna get out no matter what !! Grrr ..
    Fuck it ... i`ll have to give it to my mechanic. Had no space to use a breaker bar under the car since it was jacked ... damn.. <_<
    Must admit cars in japan are built industructible ~
  17. reckedracing
    NY
    what??
    an electric impact handled what a air gun couldn;t?
    what kind of electric impact? or was your air gun a POS?
    and wtf are you talking about?
    how did you not have room? what mounting bolts?
    give us more info and we'll help you finish the job...
  18. vtecjdm
    Hehe .. its a japanese make impact gun .... damn powerfull i may say ... still have my hands shaking.
    The transmission on the back is held up by a 17mm bolt and 2 19mm bolts (basically the trasmission mounting bolts on the back) ... to remove them u have to get access them from under the car at the back of the engine.
    Since my car is jacked up on stands (and the powerfull impact gun couldn`t take them off!! ) .. my only option would be breaker bar .. but i`ve barely got space for my self under the car .. let alone a long breaker bar .. got it now ?
  19. reckedracing
    NY
    you;re talking about the tranny bracket?
    why not just remove the one mounting bolt? and pull the motor with the bracket still on...
    it'll be tight but you should be able to get it...
  20. vtecjdm
