you;re just trying to drop the tranny then?
first hint, extensions EAT torque...
if you have trouble with a bolt try getting rid of the extensions...
i see your spacing issues...
first i would advise removing the o2 if you have the proper socket, that will give you more hand room, and those things cost a bit if you break them...
then i would get a 1/2 inch ratchet and a pipe...
you may need to get the car up higher to fit the pipe in there for the leverage you need...
