black box on back of motor? help
Discussion in 'General Tech and Maintenance' started by 92tegGP, Apr 14, 2008.
  1. 92tegGP
    92tegGP The Slut
    North Jackson, Ohio
    There is the black box on the back on the back of my b18 im thinking it has something to do with the cooling… 2 hoses go into the top of it and then the bottom hole goes into the block. Well I broke one of the nipple things that the hose connects to on the top and im trying to find a new one and I have no clue of what the “proper” name is for this black box. Can anyone help me out?
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    if one of te hoses come up through the IM and then go into it,,thats part of the pcv system
  3. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Breather Chamber...vents excess crankcase pressure.
  4. BrokenRex
    BrokenRex New Member
    more importantly, it removes oil from the pressurized air before venting it to the intake manifold. it's basically an OEM oil catch can.
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    no i dont think so,,,thats why you by catch cans,,because this one doesnt pull the oil out,,it dumps right back into the manifold to be burned
  6. BrokenRex
    sure it does. if it didn't catch oil, why not just put a pipe fitting on the back of the engine with a hose coming off of it? and you buy oil catch cans because no can will ever remove ALL of the oil. and secondly, some vehicles do not come with one, they only have a PCV valve.
