Black sut on tip of exhaust and rear bumper?
Discussion in 'Civic and del Sol - EG and EK' started by 93civicracer, Dec 22, 2008.
  1. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    What could be causing this black stuff to get all over my exhaust tip and rear bumper?
    I HAVE been having electrical problems with the battery dying constantly, could this be causing bad ignition and a rich condition?
    I've already got a new alternator and battery on the way, and I'm going to check the electrical system for shorts tomorrow but if anyone knows something else that could be causing this let me know. Thanks.
    1 person likes this.
  2. haao13
    haao13 New Member
    PA
    i dont thinks its an electrical problem. its probably just carbon but it could be that its burning oil. my old accord and d15 did and my bumper was always covered
  3. 93civicracer
    Texas
    Yeah, I'm getting the battery and alternator because they're done anyway, and I really think there's a short in the wiring.
    So you don't think that a pretty much dead battery with no alternator could make it run rich and spit out that sut because of a weak spark?
    I think it could also have something to do with the way I screwed with the exhaust, I have a buddy club racing spec 2 full exhaust connected to a test pipe so no cat (yea I know frickin L-O-U-D, but not too bad with silencer :)), plus I'm using the po8 ecu with my swap so I snipped 3 of the 4 o2 sensor wires since I don't need them.
    And I really doubt I'm burning oil, I changed the head gasket like 5 months ago and fixed my overheating problem. I'll probably get a compression/leakdown test done soon.
  4. hondasaurus
    hondasaurus Member
    VA/DC
    nice car. are you sure the black on the bumper is soot? and not discoloration/burn from heat from the muffler being too close?
  5. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if its black its prolly oil burning if its brown its running rich
  6. haao13
    haao13 New Member
    PA
    :werd:
  7. autox 89 dx
    autox 89 dx Member
    SF bay area
    And I really doubt I'm burning oil, I changed the head gasket like 5 months ago and fixed my overheating problem. I'll probably get a compression/leakdown test done soon.[/quote]
    Just becaue you changed the head gasket doesn't mean you can't burn oil. It could be leaking from the valve seats or guides.
  8. George777
    George777 ^^ Likes Bewbies
    With your mom
    Or rings.
  9. austin20110
    austin20110 New Member
    Northern Va
    do you put alot of tire shine on your car lol
  10. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    ^ lol nice.
    Has your car had a tune up lately, maybe even a fuel filter change? All those should help clean up your fuel and ignition. Timing also.
  11. Ethan
    Ethan Well-Known Member
    Clog your exaust up. BAM! No more black exaust tip. :thumbsup:
  12. 93civicracer
    Texas
    Nah it recently rained before I took that picture the driveway was still wet :D. When I get some GSR 15's and some tires then I will.
    It's basically a d15b vtec in the exact shape it was in when I got it from hmotorsonline. All I've done since then is change the head gasket and set the timing right.
    The sut is black, not brown and I know it's not heat because it's like a fine powder it just wipes right off. It looks hella shitty if I drive for about a week like that.
    My guess would be carbon since it's so fine'a powder. Could have something to do with de-catting and running the p08 ecu with less emissions or something?
    Either way I'm going to have a compression test done soon.
  13. haao13
    haao13 New Member
    PA
    scratch the no cat idea. i have a s2 testpipe and i dont have any black on my bumper. i say its burning oil
  14. 93civicracer
    Texas
    I'll check it out whenever I get time, thanks for the responses.
  15. 99sidude
    Ohio
    My vote is that it's running rich. I have a boosted setup, and it's tuned to run rich at wot and during warm up. If i run it hard at all when its warming up it will spew out a nice soot cloud of carbon. The tail pipe has a nice back sooty film on the inside, but nothing gets on the bumper. The car does not burn any oil at all.
  16. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Definitely could be running rich or oil.
    About burning oil; a bad head gasket is not the only way to burn oil. You PCV could be bad(matter of fact, the PCV and head breather tube allows a lot of oil-vapor-filled air to be ingested), bad rings, leaking valve seals, etc.
  17. 93civicracer
    Texas
    I really doubt it's burning oil. I check the oil on a regular basis and it's always been fine, just gradually gets darker like normal. Besides, it's a very very fine powder like carbon. One time it spit out a couple chunks. Still gets hella good gas mileage :thumbsup:
    Either way, I'm going to have a compression test done when I get new tires so I can get this car back on the road.
  18. serrilion
    serrilion In my own little world! VIP
    Vermont
    Um here is my thoughts mite sound stupid. But my Tip used to be to close to my rear bumper and use to make the bumper hot and melt the crap + the dirt in it, made it soot, black soot... was teriable... just an Idea for u!
  19. jdmrex08
    jdmrex08 New Member
    are you sure your exhaust is shooting black chunks? if so i might look into some new piping if i were you or maybe even a new head lol but the bumper being black is probably because of your muffler being close to the bumper, happened on my friends coupe
  20. 93civicracer
    Texas
    The bumper looked black because of the shit all over it, it just wipes right off.
    Nothing wrong with my piping, except maybe the test pipe not being the same diameter as the buddy club exhaust I have on there and I had this problem even with completely stock exhaust with fart cannon that was on the car when I bought it.
    The bumper's not burning.
