In most cars you start with the wheel furthest from the master cylinder. Then go on from there. Make sure you have a one-way bleed screw or some one to help you, or a mighty-vac brake bleeding kit. Just pump the brakes till you get good pressure then hold the pedal and open the bleed screw. Once all the air or fluid comes out still having the pedal depressed close the bleed screw. You normally have to do this about two to three times, it all depends on the amount of air in the lines. O by the way did you bench bleed the Master Cylinder? sorry for my jumbled words i have been up for awhile.
