Hello,
I have a 93 del sol with a JDM D15B and a T3 turbocharger. I just shot a rod thru the block due to a loss of oil pressure so I'm picking up another JDM longblock saturday.
This is my first time swapping a motor myself and I signed up here for help.
So far I have removed the turbo, manifold, ewg, wire harness, vacuum lines, grounds, etc
I'm pretty sure all I have left is the fuel line, axels, and shifter...
Does anyone know if I'll need special tools at this point?
I plan on swapping my trans, clutch, starter and injectors over to the new motor.
eventually I will do the timing belt, head bolts, pumps etc.
