blew a rad in the hatch
skellagher
Elder Driver
so my radiator took a shit... couple questions.... i have a brand new in box da integra rad will that bolt right into the ef hatch if so what rad hoses are used... if i go with the factory radiator what lower radiator hose do i use with a b16
You just use the integra hoses. They might need cut back a tad. I have a set ofDa hoses on my b16a ed.
can i use the integra radiator
Doesn't take much to switch them out and see. I have the stock ED rad in mine right now so I couldn't tell you. I have a feeling the DA integra rad is going to be to tall.
it will fit you just cant use the rubble groments you have to lay some kind of rags on the bottom to make sure no holes get in the bottom of the rad from rubbing but it will fit will modifications
i just installed a nice aluminum da integra rad in my 88 sedan. fit perfect. even used the rubber grommits. had to oval out the two brackets a bit but it all worked.
