Block Guard
Discussion in 'Engine Building' started by b18b1_delsol, Jan 21, 2009.
  1. b18b1_delsol
    b18b1_delsol New Member
    Ohio
    I have a b16 with 84mm Darton Sleves, I would like to be around 450 hp. Should I install a block guard while I have the motor apart or will I better off without it? Thanks
  2. efhondakid
    Akron-Canton, Ohio
    If its been sleeved you dont need a block guard.:bonk:
  3. b18b1_delsol
    Ohio
  4. Matts96HB
    Matts96HB . Moderator VIP
    Thank god you did it right the first time. Sleeving > Block Guard. The block guard is kind of the cheap man's solution to sleeving.
  5. b18b1_delsol
    Ohio
    Yea i just wasn't sure if i still had to run one or not. new to the whole motor build scene.
