block guard?
Discussion in 'Forced Induction' started by javenger, Apr 8, 2004.
  1. javenger
    javenger Junior Member
    do you all recommend using block gaurds? if so, why and who makes a good block guard? if not, why?
    would you use one on a ls/vtec, all motor?
  2. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    some people do, others don't because it keeps coolant from reaching parts of the cylinder sleeve and it can create hot spots which aren't good.
  3. pissedoffsol
    useless.
    98% of cracked sleeves START at the center, and work their way up.
    the block guard at the top does nothing but add heat to the combustion chamber, leading to more detonation, leading to more cracking in the first place.
    sleeve it, or leave it stock
  4. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    :werd:
    The block guard won't prevent cylinder wall failure, it'll just catch the rod that would sling through the block, and even then, they don't always work.
