Block Posts, Where can I get some?
Discussion in 'Engine Building' started by 5speed4life, Oct 31, 2004.
  1. 5speed4life
    5speed4life Senior Member
    Cleveland Ohio.
    Hey, Im building up my d16z6 and i want to post it. I heard that these posts were made of the same alloy that the block was made out of so the heat expansion wouldnt crack the block. But i dont think i can just walk up to the hardware store and get some setscrews. Im not trying to get 800 hp out of my d16, but any extra insurance would be good.
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    no offense, but it really isn't worth it. I really doubt your ever going to get more thsn 250 hp out of the d series which isn't enough to spend money on block posts.
  3. StyleTEG
    StyleTEG Senior Member
    www.theoldone.com
    Cheap to do, probably costs less than $100 for the posts, tap, drill bit, and epoxy.
  4. Loco Honkey
    Loco Honkey Banned
    lol... you're retarded. There's a few guys on HT making upwards of 450 HP.
  5. 5speed4life
    Cleveland Ohio.
    hey thanks. I canot find the link to the posts, but when im ready to purchase i will just email the guy.
    Im slowly building up the d16z6 for my 93 cx, and i have an IHI turbo, Je pistons, Eagle rods,
    and im savin up for the valves, springs, retainers, and cam.
    I figure if i already spent this much money, i may as well go the extra step to protect it.
  6. brian11to1
    brian11to1 Senior Member
    Im an idiot, what's a block post?
  7. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
  8. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    not the same way better they are made from the same alloy as a honda block so they go throught the same thermal cycles
  9. 92civicb18b1
    Key word "few", there aren't many people making that kind of hp on a D. It depends what his goalis, if he's just going for like 200-250 then its a waste.
    I don't know much about IHI turbos but I don't think they can push more than 250 hp.
  10. phunky.buddha
    Dallas / Fort Worth, TX
    They can break 400hp easy on the STi. :lol:
  11. projekteg
    projekteg Senior Member
    ihi has more than one size turbo. ihi rhb5's are the most common and they are very small and won't make more than 250 whp if that. block posts are 30 bucks from endyn aka, the oldone. it's key to drill in the right spots so that the posts support the cylinders in the highest stressed areas, also, it's a good idea to get the block honed afterwards b/c installing the pins can knock you cyls out out of wack if you torque them down too much. about 2ft/lbs. is suggested.
