Blockguard...yes Or No?
importimage
Should I use a blockguard for my CR/VTEC turbo application running 10 psi boost....mayble 12 psi boost??? If so, which brand would you recommend???
Thanks
you should get it sleeved
but the cheap way would be to use a blockgaurd
and STOP DOUBLE POSTING!!!!!
I don't have one so I can't say for sure but I have heard many people say the B20 won't hold boost. A LS block is cheaper and you can sleeve it up to I think 86mm. Thats your best bet.
