Blow Off Valve Sound
Discussion in 'Forced Induction' started by import_racer, Aug 20, 2003.
  1. import_racer
    import_racer Member
    When I switch gears, and once I get into the next gear, the blow off valve sounds gets cut off. Is that normal? In videoclips, I hear the full sound of the blow off valve. With mine, when I shift, you hear the blow off valve but once I get into the next gear, it goes away. So if I shift quick, you only hear it for half a second or so.
    _______
  2. MarkJimenez99
    MarkJimenez99 Senior Member
    Check your blow off valve adjustment. Your BOV is probably set to "Hard" which means that you have to rev it really high to hear the full sound. My Greddy type-s bov adjusts by turning a screw.
  3. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    indeed, that would be true especially with a smaller turbo and/or low boost levels. Not as much pressure would build up, and if the BOV is set too tight it will shut early.
  4. import_racer
    import_racer Member
    How do you loosen it? Tighten the screw or is it the other way around? I have a vortech bov that came with the kit. Thanks.
  5. Loco Honkey
    Loco Honkey Banned
    That would be normal. See, the BOV only opens when your throttle is closed and your manifold is in vacuum. Once you get to the next gear and crack the throttle, the BOV closes. These other guys are right, but they're not on the right track to answering your problem.
