blower motor
Discussion in 'Body / Exterior / Interior / Cosmetics' started by geminianm1, Dec 7, 2005.
  1. geminianm1
    geminianm1 Junior Member
    my blower motor broke so i got a new one and i dont really know how to put it in and i dont want to spend $50 to get it put in. i have a 1990 crx please help, thanks.
  2. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    you will need to go buy a manual. And its not an easy task it takes some skill to do, probably 2-3 hrs depending on what wrong and what needs to be replaced
  3. reckedracing
    reckedracing TTIWWOP VIP
    NY
    what?
    3 screws, how can you not know how to replace it?
    if you can't manage the three screws then drop the glove box, takes out the 10mm bolts holding the blower motor assembly in and drop the whole thing
    blower motors are usually just a broke wire on the contacts inside, pretty easy to fix if you can solder
  4. geminianm1
    i got it in and installed.. yea it took about 2 hrs and that was probably the hardest thing i have ever put in a car it sucked lol.
  5. hcivic.com
    i did not say it hard but takes some time due to the crampt spaces and by the time you repair it clean it and ect its 1-2hrs
