Flippinjig
The light bulb is starting to come on but it is still dim. Both motors are OBD-1 MPFI. Is that the type of wiring?
haahaaa thats it! i knew it was gonna show up on this thread!This one?
I used this site and book while doing my swap and the info in both made it go very smoothly.
i would think notI twisted off a 3/8 ratchet trying to get the head bolts out. Wow, should they be that tight???
isnt therre a new adapter that can be used to mat a b series motor to a d tran?? or is it the other way around?/
The only reason why a d15z1 gets great gas mpg, is because the intake ports are tiny, doesnt require so much fuel and air, as well as the pistons are low compression. other than that your stroke and deck heights are the same as every other 1.5 block. Im only using a z1 block for a build because its a good block, No signs of over heating, when i got it, green coolant, block surface looked brand new, new water pumps and oil pump. and i only paid 100. Even though i didnt realize till later. i didnt want the head. I'm switching the pistons from a d15b and the P08-1 head. I'm basically doing the same build as blanco. but not as clean as his is. Even though after seeing his now. I want to take that extra effort to make it look even better. yes.. im jealous of you blanco.
If i were you. Just pop the Z6 in. Unless you want to build the z6. then go ahead and put the z1 in. save gas and money, build a stroker from the z6. Im not sure if i got my numbers right. but you could find a d17 block and use the crank shaft (the main bearings are the same size) and then use 1.5 rods on the 1.7 crank and you have a stroker. of course I dont have my numbers right. I havent taken the time to check to see if that adds up right. but Either way. it'll be cheaper than a full stroker kit.
I put the Z1 in with Z6 head, intake and exhaust. Z1 exhaust manifold would not bolt up to the existing exhaust pipe because the bolt pattern is different. Kinda doggy. The stroker sounds interesting. Can you tell me more?
