Blown head gasket?
Discussion in 'Civic and del Sol - EG and EK' started by b16civic, Dec 26, 2006.
  1. b16civic
    b16civic New Member
    alright my d16 started to make a knockin noise on the way home the other day. i brought it home and checked the oil. it looked really thin and watery so i changed it. once i did this i took it for a drive and it quit for a little bit. well my step dad said it sounded like it was the timing but i told him it sounded like a rod knock. well my brother in law listened to it and said he thought it sounded like a rod knockin to. i showed him the oil and it looked like water. so we opened the radiater and i stuck my finger in it and it had a little bit of oil floatin in it. so we opened the overflow and he stuck his finger in it and pulled out a big gob of oil. he said head gasket, cracked head, or cracked block. does any body have any ideas if that is what it could be. and also i had just put an aem cold air intake on it could that have anything to do with it. any info is more than welcome thanks.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    no the aem wont matter its got a crack in the block head or its the head gasket
  3. b16civic
    b16civic New Member
    i didnt think it would my brother in law said it could but i disagreed thanks for the help.
  4. b16civic
    b16civic New Member
    alright i think the watery oil has caused a rod beo start knocking does anybody know if there is a way to take the oil pan off without seperating the tranny from the block. i can see if its the rod and which one and also possibly fix it without takin the motor out. if i have to though i will take the motor out and put new bearings pistons and rings in it. any help would be nice.
  5. herminshs
    herminshs Junior Member
    My man, I think that the best advice anyone here can give you is to take the whole thing apart, and put it the new rods and rings. You will be better off.
  6. Dasfinc
    Dasfinc New Member
    Something is blown, I just finished replacing the Headgasket on my CX and its not as hard as you'd think... but the Ticking is another story... you'd almost be better off hunting for a new motor than messing with 'guess and check whats broken' I know this from experiance... :(
  7. 96EKB18C5
    96EKB18C5 New Member
    How many miles on it?I blew mine up too, D16y8.Same symtoms.Had the head resurfaced /valve job/ magnafluxed /new head gasket.Ran fine for another 1000 miles until I blew a piston ring.I was told the stronger compression from the reworked head blew out the bottom end because it had too many miles on it, 180,000.
  8. honda big block
    honda big block New Member
    why is your name b16civic if you have a d16... anyways bro chalk it up as a lost and get that b16 or rip it apart, fix it and have strong one cammer jammer...good luck man
  9. AHHVTEC
    Alabama
    well why is your name honda big block if you dont have a honda big block
  10. honda big block
    a B20VTEC is big to me... but maybe not too you.
  11. AHHVTEC
    Alabama
    well everyone knows the honda big block is the h22a
  12. honda big block
    well...your kinda right but what's the biggest B-SERIES block?? ummm...that would B the B20 right? so i kinda have aa honda big block, right?? i could be wrong
  13. AHHVTEC
    Alabama
    well as far as displacment the biggest b series is a prelude b series :D:D lol but i know what you mean lol
  14. honda big block
    LOL is right thanks man... :cool: but that still a b20...i think
  15. AHHVTEC
    Alabama
    b21 lol
  16. honda big block
    i guess man....b21 huh?? you got me there... dohc or sohc??:huh:
  17. AHHVTEC
    Alabama
