Blown Turbo'd Engine
Discussion in 'Forced Induction' started by YangpaNemsay, May 21, 2003.
  1. YangpaNemsay
    YangpaNemsay Senior Member
    Okinawa, Japan
    On a blown turbo'd engine, would the whole turbo "system" be salvagable from the engine bay?
  2. pissedoffsol
    most likely.
    if its the motor that blew up, chances are the turbo is still ok.
    check for shaft play in the turbo, as well as try to figure out what caused the blowing- a boost spike? bad waste gate? line blew off? etc
  3. PROFILES2000
    PROFILES2000 Member
    well if the motor was blown due to a spun bearing ( when the motor isnt getting enuff oil) then i would say that the turbo is shot also. (turbos need oil to live dont forget this.)
  4. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    you can have enough oil and still spin a rod bearing from abuse. It would be useful to check though. just have to go look for yourself what happened
