Revving the car in neutral to make it move isnt a good idea. Unless im reading you wrong.
Well if its not to do with having oil put in the bores for transport or from the engine just sitting about for god knows how long
Im thinking its maybe you valve stem seals
I am having the same problem with my y8
Blue smoke in high revs and using oil
I did a compression test and it was fine
So next step is to do a leakdown test which will show you if it is valve seals or head gasket
I think your best bit is to take it for a good drive and see if it clears up
If not get a leakdown test done, it will tell you alot
So did taking it for a spin at the weekend help ?
Well I
sounds like your block is cracked.....since u said theres no coolant in the oil then no blown headgasket....thick blue and or white smoke means cracked block for sure.....time for a swap........
white/ black= cracked head gasket means that it was cause from blown headgasket
blue/white= cracked block
