BMW M3 throttle's on k20z4 motor
Discussion in 'Engine Building' started by Hendri, Sep 15, 2014.
  1. Hendri
    Hendri New Member
    Hi guys looking at installing BMW M3 throttle's on a k20z4 motor, just wanted to find out if anyone has atempted something like it.
    Installed electric water pump (tyred of replacing head gaskets every time the altinator belt comes off and the car overheats) on k20 some tunning and 138wkw 276nm torque, all stock internals.
    The throttle in theory should work, not doing much for the kw but should increase the torque.
    Have seen throttle's on a k20 witch is pushing 151wkw normal aspirated then again the guy spent a 3400 dollars on a set of throttle's. Fully forged motor though.
    Saving money were I can for more mods that make sence.More bang for my buck I guess.
  2. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    How many mm is the BMW throttle body? I'm guessing it's cable driven.
    I doubt the bolt pattern is the same so you'd need to fab up an adapter plate. Proper TPS and IACV situation? (IACV can be deleted with K-Pro)
  3. Hendri
    Hendri New Member
    Will have to fabricate an adaptor plate and reposition the tps just need to get the injector angle corect with the valves.The intakes ports are almost identical will have to drill, tap and stud for the M3 throttle's on the adaptor plate.IAVC not a problem.
  4. Hendri
    Hendri New Member
    The M3 throttle's are 52mm
  5. phunky.buddha
    Dallas / Fort Worth, TX
    When it comes down to it a throttle body is a throttle body.. if you're willing to (and know how to) fabricate your own mount setup and linkages it won't be any big deal. 52mm should work fine.
  6. Hendri
    Hendri New Member
    Will post some pics as soon as I get the adaptor plate done with the right angle, the linkages are standard as used in the BMW's the bigest tric is getting the injector angle right to spray direct into the valve chamber.
  7. eg6sir
    52mm is small.. stock b-series is 60mm
  8. phunky.buddha
    Ooohhh. Thought he was talking individual throttle bodies? His title had an "S" after throttle. Granted there was an apostrophe too, but I assume plural.
  9. eg6sir
    Could be... never heard of an M3 coming w/ itb's so I assumed he meant throttle body
  10. E_SolSi
    they have always had ITBs
    the e30 had them
    the e36 didnt have them here but had them in Europe
    the e46 had them
    the e92 had them
    not sure about the newest f80 m3 / f82 m4 with the twin turbo inline 6
  11. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    I assume he's referring to E46 S54 throttle bodies. And yes, they'll work with some fiddlin'
  12. eg6sir
    Learn something new every day. :)
  13. Hendri
    Hendri New Member
    Sorry guys yes the throttle's are from the E46 BM trouble u, having a look at the M5 throttle's for the B series as well, might work with a few mods.
    The throttle size 52mm not the ideal size (54 mm -60mm would work better ) but more interested in the lenth of the throttle's make a big difference, so far the lenths that seem to work are between 140-145mm from head to butterfly. Need to check the difference on the dino.
  14. phunky.buddha
    Length as well as diameter matter
  15. Jeef
    Jeef NO MA'AM Moderator VIP
    Thats what she said
    phunky.buddha likes this.
  16. phunky.buddha
    As well as velocity and smoothness of flow through the stack.
    Ba-dum-pssssh!
    Jeef likes this.
