i just put us up on the latest release which fixes a bunch of bugs. BUGS FIXED (IPB 2.1.4 -> IPB 2.1.5) 1. [ACP] If your ACP session times out, and you click on a template group, or template bit, you are redirected back to that page after logging in without the ACP wrapper 2. Using the search engine, members can read invisible posts and topics if the Mode is set to Manual, or is set to Full Text, with Advanced Method enabled. 3. Secondary member groups not honored for forum and topic tracker emails 4. API - member information is reset by the topics/posts API, can cause problems if API is used from within IPB source files where member information needs to be checked again later 5. My Assistant does not close properly if you do not have access to view the board 6. Admin logs show login name instead of display name 7. Submit button does not work in Firefox if you hit the back button on a form 8. Renaming an emoticon folder in the ACP causes the emoticons not to show up on the post screen 9. Users are able to post new topics to root categories (even though setting indicates they should not be able to) 10. Subscription Manager currency editor only allows up to 3 digits before the decimal point 11. Certain conditions can cause regex sql to print bad html 12. Hardcoded text 13. Smilies always insert at end of fast reply area 14. [RTE] IE - insert list does not work properly as of 2.1.4 15. [RTE] PHP variables used in the fast reply result in a regex error 16. Settings page sets all field types to 30 for input fields (instead of text) 17. Bad upload url getting inserted on install 18. Avatar setting under User Profiles is not used anylonger 19. Deleting a forum assigned to an RSS import causes a bad entry in the forum cache 20. [ACP] Number of registered members count does not update when adding a member from the ACP 21. open_basedir can produce php warning on some php versions if load limit is to be checked 22. [ACP] Changing the last registered member's name/display name does not update the stats 23. With force login enabled, the http_referer is not set, and users are not redirected back to the page they requested 24. [RSS] Some php versions returning inaccurate times for RSS imported articles if feed does not supply the time 25. Rebuild tools not running on the correct number of items at a time 26. Lost password form will not allow you to complete request if Script/Bot control is set to 'None' 27. RTE - Multiple font tag attributs (i.e. size and color) get nested into one tag and one value is not honored as a result 28. Doublequotes used in the prefix/suffix field when editing a group cause the form field to break 29. Max email length was increased, however the DB column was not updated in 2.1.4 30. Apostrophe's are converted to html entities when clicking 'More Options' from the Fast Reply 31. HTML used for table header in Messenger functions causes a small second th row 32. Personal photo popup window not dynamically sized, can result in scrolling 33. Minor javascript error in the pm card popup when logged in as a guest 34. Only one calendar event per day showing in forthcoming calendar events on board index 35. Inconsistent HTML used for profile view 36. Unterminated html tag for smilie table 37. Approving/unapproving posts from within a topic, the moderator action is not logged 38. Task Manager goes to top of page when you click link to see Cron CURL code 39. Minor typo in ipb_settings.xml 40. Forum inline moderation - 'With Selected' defaults to 1 if no topics selected 41. no_reg variable evaulated instead of being set in index.php when board is offline 42. UTF-8 charsets double decoded incorrectly when using AJAX 43. New ACP restrictions against Admin Splash page undesirable for some users - added a new perm key specifically for Admin Splash page 44. System javascript error in IE6 when using AJAX if using Russian character set 45. Some of the index.html files are outdated (refer to free copy of IPB) 46. 0 byte index.html file causes upload issues with some FTP clients 47. SQL error for specific versions of MySQL using specific filtering options on forum view (ambiguous column error) 48. Email topic emails not applying email settings properly 49. Profile does not show anoynmous user location if group has ability to view anonymous users 50. Contact member emails not applying email settings properly
they send out an email... but you're member # 23423234234234 so you get it last and it takes a few days to cycle through.
