Body Swapping Question
Discussion in 'HYBRID -> EG-EK / DC' started by SiCrxSi, Mar 23, 2003.
  1. SiCrxSi
    SiCrxSi Member
    lancaster, CA
    does anyone know if a intgera body parts will bolt up to a 88 crx. i want to change out my front end with an intgeras(hood and fenders). Im wanting to put the long head light style fornt end on it.
  2. machine
    machine Banned
    houston tx
    www.superhonda.com your killing two perfectly good cars :huh:
  3. E_SolSi
    just kill yourself and save two innocent cars from a humiliating death
  4. SiCrxSi
    SiCrxSi Member
    lancaster, CA
    i got this pic from someone else that posted it here.
    I think both you guys are just dicks so it doesnt matter. nothing looks bad about this so whats the problem. Or maybe you both think i should just follow your ideas cause you both have so many post....maybe that just means you spend a little to much time online. I guess it just matters how you're looking at it. just wanted some help not some dumb ass replys but oh well if you can't be a bad ass in real life why not do it online.
  5. crxracing77
    crxracing77 Senior Member
    west lafayette in or clw florida
    some modification will have to be done, but i dont think it is too bad or to expensive to ge done! the more you post on here you will see a lot of ppl on here are very opnionated... Just blow it off... u should get some good replies soon! sorry
    chris
  6. D See 2
    D See 2 Senior Member
    Baltimore, MD
    gawwd i love that car.
  7. whatdahieu
    whatdahieu Senior Member
    no need for harsh words, anyways i had 2 friends who done this front end swap however it required them to use the whole front end of the tegs...headlights, fenders, bumper, hood and the radiator and core supports for the tegs front end.
    if you got a 88-91 it makes it easier cause hood bolts right on.
    you better have a welder and a recioperating(can't spell it) saw though cause you need to cut the integra and the crx fenders in half and weld the rear of the crx and the front of the tegs together so it can fit also you need to saw off the current core and raiator supports off the crxs and weld on the integras.
    it should allow the headlights to mount easily as well as the front bumper.
    do not forget to splice the headlight wires and mate the tegs so you can utilize the tegs headlights.
    oh i hope you are good with sandpaper, grinder, bondo and fiberglass cause you gotta make the weld line in the middle look good.
    i hope all this info is accurate but i do not know for sure i will find out and make any corrections if neccesary.
    hope this helps. :)
  8. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    If you can do the work mostly yourself it would be alright, sending it to a shop would get pricey though. Whatever people say, that rex is phat as hell. bottom line. It's your car, and as long as your not ricing it out, do what you want to it. Just make sure with those body mods come some sweet engine work :)
  9. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    as or welding you need a mig or tig unit
    take your time spot weld air spot air until you have a complete seam then grind flush you should need very little bondo
    also dont use a saw use an air nibbler the leave an better edge
  10. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    I think that looks tight. If I had a crx I would definately switch the headlights and tailights. ITR headlights with 97-01 Lude tails. hells yea.
  11. sportlinecrx
    sportlinecrx Banned
    that is the sweetest crx front end i have ever seen! thing is, it doesnt look that much diferent from the JDM front clip, which would be ALOT easier to do. if you did the JDM clip and used some clear corners and projectors, it would look almost exactly like that.
  12. whatdahieu
    jdm sir would be easier might even look just as good kind of think of it :rolleyes:
  13. LXVTEC
    LXVTEC Member
    I have a friend who just did this to his Rex. He used the integra headlights, hood and bumper. The fenders have to be welded to together using Rex rears almost up to the corner light section and the integra front half. for mounts he made his own using box tubing so he could mount the Fluidyne Del Sol radiator, and intercooler. so he just mounted the bumper and headlights to the fabed radiator support. he also made his own front crossmember as well using box tubing.
    I am thinking of doing the Teg front end on my 89 LX 4-door as well. It will make smog easier for me I think since the local smog shop would think it was a Teg because the LS sticker would be under the hood to match the motor and I am swapping in a Teg dash as well to go with the Teg suspension, brakes and harness.
    Just do it if that is what you like.
    BTW: The Rex in the picture just has the one piece headlights with a cut Rex carbon fiber hood and a I believe a Wings West front bumper. It still looks sweet.
