bogging @ vtec
Discussion in 'General Tech and Maintenance' started by Guy, Sep 29, 2003.
  1. Guy
    Guy Senior Member
    Yuba County
    obdo b16a into a crx dx
    zdyne 1 wire acu (though the all wires are still hooked up)
    ok well the motor is in and it runs great, until i hit vtec. when i get into vtec range it starts to bog. any ideas as to what it may be? thanks
  2. GSRCRXsi
    MD
    make sure your cat isnt clogged, run open header to make sure. i know B16's cat was clogged and it bogged at vtec
  3. Guy
    Guy Senior Member
    Yuba County
    it should be ok as i just swapped a relativly new high flow cat from my integra over. but thanks
  4. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    what other mods do you have done? maybe your car is not ready to hit VTEC until a higher RPM, if that is the case get a VAFC, and raise the VTEC engagment.
  5. Guy
    Guy Senior Member
    Yuba County
    hmm, well i guess ill list everything that ive got
    intake/header/skunk2 stg1 cames/aem cam gears/ skunk2 IM/ hondata IM gasket
    wierd thing is that im taking this out of my integra where everything was working great(though the skunk2IM and hondata IM gasket are just now put on). im hoping that i dont need a vafc. thanks
  6. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    what RPM dos vtec engage at?
  7. rudeludenotmeanthough
    rudeludenotmeanthough Senior Member
    there ya go. bingo
  8. Guy
    Guy Senior Member
    Yuba County
    it engages as it usually does at 5200.
    i appreciate your effort but i am absolutely sure it is not from the cat as it is the one that was on my very much working integra before.
  9. RFHOMI2U
    RFHOMI2U Senior Member
    Sounds like ignition timing to me. Try advancing the distributor about 2-3 degrees. I had the same problem and that's what cured mine. Also, even tho you have a high-flow cat, it could be clogged. I have seen some friends buy the crappy brand ones and they clog up really quick. VTEC needs higher flow. And don't quot me on this, but with stage 1 cams, you should probably check to make sure you have enough fuel flow. It might be starving for fuel. check into the possibility of a fuel filter. And yes, I know it sounds like a lot, but I'd even check to make sure the plugs are not fouled.
  10. B16
    B16 Super Moderator VIP
    yay area, CA
    and mine was on a very much running b16 before when it went. its not like it gradually goes, easy to check out. other than that, timing? it drives totally fine on the low cam lobes?
  11. arpee79
    arpee79 Senior Member
    OK good some one beat me to this I have exactly the same problem my Vtec kicks in at 4900. 1 gear it takes off 2 gear goes in and boggs then starts to pick up then vtec comes on and it boggs again after that this shit start to pull nice with balls..I tried advancing the timing my exhuast is stock from my 90 civic hb
    mods or on my SIG. Can the timing belt being a little loose cause
    Im going to try to change fuel filter first.
  12. Guy
    Guy Senior Member
    Yuba County
    well about the cat, it is a carsound high flow cat and unless it somehow got clogged between taking it off of my integra and being put onto my crx it should be fine, as when i drove my integra before it was put it into the crx and it was working properly.
    ill check into the timiing, but the wierd thing is that if i unplug the vtec solenoid it will rev up to and beyond 5200 just fine. but otherwise it runs great until vtec tries to engage.
  13. Guy
    Guy Senior Member
    Yuba County
    well checked and it isnt the timing or the solenoid... hmm
  14. B16
    yay area, CA
    hey, mine somehow became clogged by just changing cams... go figure...
  15. Guy
    Guy Senior Member
    Yuba County
    well its gonna be a PITA but were gonna try and change the fuel pump now so hopefully that will do the trick
  16. GSRCRXsi
    MD
    spend the 30 bucks and do the fuel filter too. unless its been done recently it wouldnt hurt.
  17. Guy
    Guy Senior Member
    Yuba County
    coincidentally earlier today i replaced that as well
  18. GSRCRXsi
    MD
  19. Guy
    Guy Senior Member
    Yuba County
    i should also mention that it stops bogging and runs fine after 6500
  20. Guy
    Guy Senior Member
    Yuba County
    well it isnt the fuel pump either... so they are just going to re-wire everything and hope for the best.
    :worthy: please oh lord of working cars, let this last trial be enough enough to allow my humble ride addmittance into your magnificent kingdom.
