boost creep at higher rpms
Discussion in 'Forced Induction' started by 95EGCoupeVtec, Nov 27, 2009.
  1. 95EGCoupeVtec
    95EGCoupeVtec SOHC VTEC at its best
    South Mississippi
    so i got everything running perfect finally on my car. it pulls hard as fuck. only problem is, after about 5200rpm in 3rd gear pulling 9psi, the boost starts to wobble back and forth closer to 10 psi then it hitss 11psi and of course the map freaks out. now it did alot colder here the temp dropped alot and i set my boost controller during the summer. could that be causing my creep? also, my WG source line comes form my turbo to WG, but i have a plastic vaccuum line connector in the middle of it. could boost be leaking out of there and causing it to creep? the car pulls fine in 1st and 2nd, thought they go by too fast and i bounce off the limiter haha.
  2. Briansol
    how in your mani set up for wastegate placememnt?
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    The Go-Autoworks cast manifold:
    ....ick
  4. 95EGCoupeVtec
    South Mississippi
    yeah thats the one i have.
  5. 97hatch
    97hatch ?
    Anderson IN
    waste gate placement is mostlikely the cause of the boost creep here what kind of waste gate do you have also
  6. civicious
    Houston, TX
    according to his signature, it's a 38mm Tial
  7. 97hatch
    97hatch ?
    Anderson IN
    is it a real or fake tial is the guestion to ask then i guess
  8. 95EGCoupeVtec
    South Mississippi
    its a real tial. also, if a 1/8 flare fitting fits fine into my oil feed line, what -AN fitting size would i need? i'm trying to get a dang oil restrictor and idk if its -4 or -3.
  9. Briansol
    the manifold is the problem. it basically gets 90% of its reading from 1 runner, not all 4.
    The only way to really fix this is to get a manifold that isn't a 1982 design.
  10. Briansol
    and -3 is the correct feed line size... not sure that it will fit your connectoe though.
  11. 95EGCoupeVtec
    South Mississippi
    lol u made me laugh.
  12. civicious
    Houston, TX
    it's funny but it's true.
  13. 95EGCoupeVtec
    South Mississippi
    honestly, idk if it was boost creep and my ecu freaking out bc of a stock MAP sensor OR if i hit the rev limiter. it hasn't done it since this one time.
  14. civicious
    Houston, TX
    either way, that's still a crap manifold design.
  15. DESPAIN
    flower mound TX
    The mani should be"ok" for 9-10psi boost.
  16. Briansol
    might've had a lose vac line or something too...
  17. 95EGCoupeVtec
    South Mississippi
    well its doing it again. i'm thinking there is a small leak where the banjo fitting screws into the wastegate. OR that the rush of additional air when the vtec hits could make it slow to respond. i'm thinking the banjo fitting going into the wastegate.
  18. civicious
    Houston, TX
    ...or it's the manifold
  19. Matts96HB
    Matts96HB . Moderator VIP
    Completely irrelevant, but ok.
    My first vote is this.
    Check everything for leaks and if everything checks out okay..
    .. then this is the problem.
    Look into something nicer anyway, especially if you are looking to make decent power.
  20. 95EGCoupeVtec
    South Mississippi
    for right now i'm fine with this cast manifold. what i would like to do is get a spare z6 block and go vitara/eagle and then upgrade to a mini ram or full ram. and as far as the vacuum lines go, which would would i check? the one going from the turbo pressure nipple to the wastegate, the line for its measurement?
