Boost for Newbs
Discussion in 'Forced Induction' started by Uncle Buck, Dec 6, 2007.
  1. Uncle Buck
    Uncle Buck JDMDecals.com guru
    Spearfish, South Dakota
    Boost for Newbs.....
    http://www.honda-tech.com/zerothread?id=248965 - truth about EGT's
    http://www.honda-tech.com/zerothread?id=221260 - propane injection
    http://www.homemadeturbo.com/forum/inde ... 10;start=0 - Jeff's Tyrus Intercooler install CRX
    http://www.homemadeturbo.com/forum/inde ... eadid=2952 - lowering boost (carb spring, jeff)
    http://www.homemadeturbo.com/forum/inde ... readid=989 - making manifold (shortyz)
    http://www.homemadeturbo.com/forum/inde ... 62;start=0 - mezbo's manifold
    http://www.homemadeturbo.com/forum/inde ... 38;start=0 - jeffs air to water.
    http://www.homemadeturbo.com/forum/inde ... eadid=2450 - a/r
    http://www.homemadeturbo.com/forum/inde ... eadid=3363 - calculating intercooler
    http://www.homemadeturbo.com/forum/inde ... eadid=3361 - testing WG
    http://www.homemadeturbo.com/forum/inde ... eadid=3359 - lowering audi WG.
    http://www.honda-tech.com/zerothread?id=373528&page=2 - chipping
    http://www.honda-tech.com/zerothread?id=366319 - clutch install
    http://www.homemadeturbo.com/forum/inde ... ic=13329.0 - Everything you need to know about oil lines
    http://www.honda-tech.com/zerothread?id=67146 -oil return
    http://www.honda-tech.com/zerothread?id=109160 -oil return line setup
    http://www.honda-tech.com/zerothread?id=114490 -oil return line parts
    http://www.honda-tech.com/zerothread?id=71999 -where to weld oil return
    http://www.honda-tech.com/zerothread?id=119100 -oil return line
    http://www.honda-tech.com/zerothread?id=119539 -oil pan welding
    http://www.honda-tech.com/zerothread?id=119715 -oil pan welding
    http://www.honda-tech.com/zerothread?id=118687 -oil grade to use
    http://www.honda-tech.com/zerothread?id=118694 -ft for oil feed line
    http://www.honda-tech.com/zerothread?id=118807 -oil feed line
    http://www.honda-tech.com/zerothread?id=119681 -oil feed line
    http://www.honda-tech.com/zerothread?id=93550 -part for oil feed line
    http://www.honda-tech.com/zerothread?id=114436 -where to buy brass t for feed line
    http://www.honda-tech.com/zerothread?id=126335 -oil t question
    http://www.honda-tech.com/zerothread?id=125438 -another place to buy oil lines
    http://www.honda-tech.com/zerothread?id=131447 -oil feed line an/npt connector ?
    http://www.honda-tech.com/zerothread?id=134078 -feed diagram
    http://www.honda-tech.com/zerothread?id=133948 -oil bpst fitting again
    http://www.honda-tech.com/zerothread?id=144586 -oil feed line restrictor
    http://www.honda-tech.com/zerothread?id=155510 -oil leaks
    http://www.honda-tech.com/zerothread?id=158018 -oil feed 3' better
    http://www.honda-tech.com/zerothread?id=156571 -oil pan bolts
    http://www.honda-tech.com/zerothread?id=170223 -oil pressure readings
    http://www.honda-tech.com/zerothread?id=168084 -oil feed fitting
    http://www.honda-tech.com/zerothread?id=131450 -oil feed diagram
    http://www.honda-tech.com/zerothread?id=195068 -oil pressu
    http://www.honda-tech.com/zerothread?id=364948 -BSPT and NPT AN explanation. ***
    http://www.honda-tech.com/zerothread?id=365360 -install of walbro 255lph EF
    http://www.honda-tech.com/zerothread?id=122635 -drag 3 (to) coolant line?
    http://www.honda-tech.com/zerothread?id=116891 -closed loop turbo info
    http://www.honda-tech.com/zerothread?id=119724 -drag 3 turbo fitment (filing block)
    http://www.honda-tech.com/zerothread?id=119690 -vacuum source
    http://www.honda-tech.com/zerothread?id=94820 -closed loop
    http://www.honda-tech.com/zerothread?id=120814 -Drag3 downpipe
    http://www.honda-tech.com/zerothread?id=120867 -Drag3 + Tial connection
    http://www.honda-tech.com/zerothread?id=118699 -wastegate vacuum line
    http://www.honda-tech.com/zerothread?id=118767 -feul pump for drag 3
    http://www.honda-tech.com/zerothread?id=121442 -fittings (brass T on block)
    http://www.honda-tech.com/zerothread?id=123326 -blow off valve tightening
    http://www.honda-tech.com/zerothread?id=123925 -catalytic converter removal o2 sensor
    http://www.honda-tech.com/zerothread?id=124474 -'burning' in the turbo + blow off valve ?
    http://www.honda-tech.com/zerothread?id=124580 -drag 3 manifold boost spike issues
    http://www.honda-tech.com/zerothread?id=124662 -drag 3 tial fitment
    http://www.honda-tech.com/zerothread?id=151845 -closed loop dump tube
    http://www.honda-tech.com/zerothread?id=155616 -flexpipe issue
    http://www.honda-tech.com/zerothread?id=159889 -blow off valve adjusting/cleaning
    http://www.honda-tech.com/zerothread?id=163453 -egt probe tapping
    http://www.honda-tech.com/zerothread?id=167329 -o2 sensor bung
    http://www.honda-tech.com/zerothread?id=170498 -don't use tial gasket
    http://www.honda-tech.com/zerothread?id=175270 -intercooler direction
    http://www.honda-tech.com/zerothread?id=175277 -drag bolts suck
    http://honda-tech.com/zerothread?id=373528 -map sensor explanation and chipping
    http://www.honda-tech.com/zerothread?id=206376 -bov greddy type s (loose)
    http://www.honda-tech.com/zerothread?id=120548 -hondata install (solder stuff)
    http://www.honda-tech.com/zerothread?id=98092 -hondata install heiarchy
    http://www.honda-tech.com/zerothread?id=121859 -hondata info on pumps
    http://www.honda-tech.com/zerothread?id=117300 -spark plugs
    http://www.honda-tech.com/zerothread?id=156273 -spark plugs (2)
    http://www.honda-tech.com/zerothread?id=116886 -changing plugs
    http://www.honda-tech.com/zerothread?id=117326 -flexpipe for good price
    http://www.honda-tech.com/zerothread?id=117733 -injectors, 440 or 550
    http://www.honda-tech.com/zerothread?id=119569 -guage for autometer
    http://www.honda-tech.com/zerothread?id=119591 -autometer guages
    http://www.honda-tech.com/zerothread?id=121452 -aero fpr
    http://www.honda-tech.com/zerothread?id=119884 -best FPR?
    http://www.honda-tech.com/zerothread?id=118885 -place to buy aem fpr
    http://www.honda-tech.com/zerothread?id=122590 -(installing) aeromotive fuel regulator
    http://www.honda-tech.com/zerothread?id=86051 -removing/installing intank fuel pump
    http://www.honda-tech.com/zerothread?id=120889 -profec b install
    http://www.honda-tech.com/zerothread?id=116651 -Radiator fans
    http://www.honda-tech.com/zerothread?id=119819 -diff between mechanical/electrical gauges
    http://www.honda-tech.com/zerothread?id=117513 -turbo XS boost controllers and tial wastegates
    http://www.honda-tech.com/zerothread?id=122396 -block guard
    http://www.honda-tech.com/zerothread?id=107030 -rc 440 injector polarity
    http://www.honda-tech.com/zerothread?id=82211 -rc 440 after hondata install
    http://www.honda-tech.com/zerothread?id=121452 -aeromotive fpr part #
    http://www.honda-tech.com/zerothread?id=125639 -hks ssbv clip
    http://www.honda-tech.com/zerothread?id=153531 -more hks bov install
    http://www.honda-tech.com/zerothread?id=125852 -carsound cat part #
    http://www.honda-tech.com/zerothread?id=92570 -turbo timer relay
    http://www.honda-tech.com/zerothread?id=128321 -turbo timer wiring
    http://www.honda-tech.com/zerothread?id=132485 -radius rods
    http://www.honda-tech.com/zerothread?id=63095 -rear seat removal
    http://www.honda-tech.com/zerothread?id=133644 -injector fitment
    http://www.honda-tech.com/zerothread?id=104940 -thermal to cat issues
    http://www.honda-tech.com/zerothread?id=136680 -egt guage stuff
    http://www.honda-tech.com/zerothread?id=137223 -which runner to tap for egt
    http://www.honda-tech.com/zerothread?id=55987 -aem fpr against strut bar
    http://www.honda-tech.com/zerothread?id=139706 -tools to carry
    http://www.honda-tech.com/zerothread?id=140003 -base fuel map
    http://www.honda-tech.com/zerothread?id=140774 -bleeding coolant
    http://www.honda-tech.com/zerothread?id=156073 -js safeguard
    http://www.honda-tech.com/zerothread?id=168470 -js safeguard, who is using
    http://www.honda-tech.com/zerothread?id=160428 -summit part
    http://www.honda-tech.com/zerothread?id=170160 -9psi, raise static fuel + retard timing
    http://www.honda-tech.com/zerothread?id=170821 -wires to tap for guages
    http://www.honda-tech.com/zerothread?id=171397 -c clamp pliers for hks bov
    http://www.honda-tech.com/zerothread?id=171314 -EGT temps
    http://www.honda-tech.com/zerothread?id=166449 -vacuum sources
    http://www.honda-tech.com/zerothread?id=175335 -assembling an fittings
    http://www.honda-tech.com/zerothread?id=176725 -oem fan clearance - move to right
    http://www.honda-tech.com/zerothread?id=193263 -greddy profec b
    http://www.honda-tech.com/zerothread?id=85987 -installing rc injectors
    http://www.honda-tech.com/zerothread?id=106033 -matching wires rc injectors
    http://www.honda-tech.com/zerothread?id=133644 -fitment of rc injectors
    http://www.honda-tech.com/zerothread?id=107030 -polarity does not matter
    http://www.honda-tech.com/zerothread?id=154935 -once installed
    http://www.honda-tech.com/zerothread?id=159623 -tips to install
    injectors http://www.hstuners.com/forums/showthre ... adid=11436
    resister wiring http://www.honda-tech.com/zerothread?id=441107
    fuel pump http://www.theoldone.com/articles/fuelpump/
    DIY boost controller http://www.geocities.com/chmwatson/FAQs/mbc.html
    DIY Oil line kit http://www.honda-tech.com/zerothread?id=432769
    Oil press sensor install http://www.theoldone.com/articles/oilpressure/
    a/f gauge install http://www.roadraceengineering.com/inst ... ctions.htm http://www.hstuners.com/forums/showthre ... readid=826
    boost gauge install http://www.roadraceengineering.com/inst ... ctions.htm
    Where to get ur parts..well most I mean
    http://www.jgstools.com/turbo/ipa.html
    http://www.turbopiping.com
    theres also more at this link http://www.roadraceengineering.com/flan ... askets.htm
    This guy sales afc and egt gauges at a good price..Dont know how they work..But if you buy one pls do a write up and review it. http://cgi6.ebay.com/ebaymotors/ws/eBay ... otunesales
    Some Tech links
    http://www.jdmfan.com/index.php?mode=technical
    http://www.c-speedracing.com/howto.php
    Over boost has tons
    http://www.overboost.com/feature_class.asp?class=1
    http://home.nycap.rr.com/ghjrsc/
    Has a few misc things
    http://www.turbocivicsi.com/
    This has hella tips
    http://www.geocities.com/chipman_13/clippings.html
    http://tech.hybridgarage.com/tech/
    b16 head removal
    http://www.lightningmotorsports.com/techb16aheadrem.htm
    450cc injector install
    Injector wiring
    http://www.hondata.com/techinjectorwiring.html
    resistor box wiring
    rx-7 saturated injector right up
    http://www.honda-tech.com/zerothread?id=415342
    gm 3bar sensor install
    http://www.hondata.com/3barinstall.html
    catch can install
    http://www.roadraceengineering.com/inst ... tchcan.htm
    Helpful piston tech
    http://www.lightningmotorsports.com/techpiston.htm
    Helpful piston tech 2
    http://www.theoldone.com/articles/engin ... sheet.html
    Replacing piston rings
    http://www.honda-tech.com/zerothread?id=427145
    d series engine building
    http://www.theoldone.com/articles/d_ser ... ding_tips/
    connecting rod tips
    b20 rebuild
    http://www.theoldone.com/articles/badtothebone/
    Greddy e-manage and e-01 install
    http://www.mohdparts.com/emanage/
    How to set a v-afc
    http://www.geocities.com/thermalfid16/VAFChack1.html
    Turbo install
    http://www.gamesbbs.com/~dmoore/turbo-install2.htm
    Bunch of stuff..They make it look easy.
    http://www.rx7turboturbo.com/robrobinet ... engine.htm
    Oil Pressure gauge install
    http://home.hiwaay.net/~lbrewer/howtooilpresgauge.html http://www.grandamgt.com/oilpressure.html
    Fuel gauge install
    http://robrobinette.com/fuelp_gauge.htm
    This is pretty cool
    http://www.v6power.net/articles/OPandWT ... _send2.jpg
    Bov Install
    http://mikeegan.stormpages.com/BOV.html
    Some install pics..Not an install write up
    http://neko.codrus.com/cars/miata/turbo-install/
    differences between b16/b18c1/b18c5
    http://www.honda-tech.com/zerothread?id=473892
    Boost Controller installs
    HKS EVC-4 EBC
    http://www.plymouthlaser.com/evc4.htm
    MBC
    http://www.volvospeed.com/Mods/dawes_mbc.htm
    http://www.lotuselancentral.com/mbc.htm
    Profec and Evc
    http://robrobinette.com/profec.htm
    Reviews..In case you still dont know which to choose..
    I know this will help some people
    Turbos
    http://www.carreview.com/ForcedInductio ... 78crx.aspx
    Boost Controllers
    http://www.carreview.com/ForcedInductio ... 91crx.aspx
    Naws...Catnip for cars
    http://www.carreview.com/ForcedInductio ... 79crx.aspx
    Superchargers
    http://www.carreview.com/ForcedInductio ... 77crx.aspx
    Engine management
    http://www.carreview.com/EngineManageme ... 74crx.aspx
    Intakes/Filters
    http://www.carreview.com/Intakes-Filter ... 76crx.aspx
    Suspension
    http://www.carreview.com/Suspension/SCT_3640crx.aspx
    Exhaust/cats/headers/etc
    http://www.carreview.com/Exhaust/SCT_3639crx.aspx
    Breaks
    http://www.carreview.com/Brakes/PLS_1579crx.aspx
    Drivetrain/clutchs/etc
    http://www.carreview.com/Drivetrain/PLS_2887crx.aspx
    Gauges
    http://www.carreview.com/Gauges/PLS_2888crx.aspx
    Listen to sounds of a bov
    http://www.socalsupras.com/tuning/blowoffvalve.html
  2. Briansol
    that list is REALLY outdated. overboost went out of business years ago...
