Boost ga. reliability vs. Map sensor readings...
Discussion in 'Forced Induction' started by rfrumusa01, Jan 31, 2008.
  1. rfrumusa01
    rfrumusa01 Bean Cakes
    Rochester, NY
    The other day I noticed something... my autometer boost gauge shows me maxing out at 14-15 psi right now. My Apexi S-AFCII (used for gauge purposes only) tops at 82kpa (converted to 11.9Psi). With the SAFC getting that reading from a Motorala 2.5BAR MAP sensor, which would you say is more accurate?
    The analog boost gauge, or the S-AFC??? It would be nice to know how much boost I am ACTUALLY running!
    Thanks!!! Pls post any experiences with this topic!
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    maybe the boost gauge has a little air leak???
    id go with the safc if its all wired up correctly
  3. rfrumusa01
    Rochester, NY
    If it had a leak, it would be reading less boost instead of more... I guess I don't understand how the voltage output from the MAP sensor can relate to an exact amount of actual pressure. I would think the analog gauge reading directly from static pressure (if calibrated correctly, and it should be) would be more accurate. Nobody else?? anyone??
