Boost Leak/ Pressure Tester Write Up
Discussion in 'Forced Induction' started by 92civicb18b1, Jun 13, 2005.
  1. 92civicb18b1
    92civicb18b1 The Trisexual
    I was explaing to this on an Audi forum so I decided HS could use a new write up.
    Make a pressure tester, and check for leaks. :eek:
    Go to home depot
    Materials:
    -a silicone/rubber coupler to fit over the intake port of the compressor housing.
    -PVC cap to fit INSIDE the coupler you just bought
    -A valve stem or fitting
    Building Procedure:
    -Drill a hole in the PVC cap big enough to pit the valve stem
    -Insert the valve stem and seal it
    -Put the PVC cap in the coupler and clamp it down.
    Operating Procedure:
    -Remove intake tube from turbo, our case would be a filter and a short pipe probably
    -Attach "pressure tester" and clamp it down
    Attach some type of source to the valve stem to pressurize the intake tubes. (i use a regular air compressor)
    Pressurize to about 10-15 lbs. That's what I do anyway, a little more shouldn't hurt.
    Listen for leaks, they're easily noticeable with a hissing sound, also spray some soapy water over ever inch of the intake if you think you're missing something, it will bubble where there are leaks.
    This is a >$10 tool that's extremely useful..
    Believe me this works very well and can save you a buttload of money in unneccassary diagnosing.
    Sorry for the crappy pics, but I still haven't bought a new digicam
    Yes mine is ugly, but it works well.
    B needs to put me on the front page. lol
  2. smooth_criminal
    smooth_criminal Senior Member
    thats a pretty good idea, BUT i'm not sure it it's a good idea to force air into the turbo and have it also leak forced air into the exhaust ports of the head? i think it would be a better idea to just hook it up the the charge piping coming out of the turbo. But i could be wrong. Either way i think i'm going ot try it. Just going ot take the turbo out of the loop.
  3. 92civicb18b1
    it doesn't affect anything. It completely safe tyo use.
  4. pissedoffsol
    hrm, i'm not so sure myself. I just don't know either way if there are any adverse effects to putting pressure on the seals of a turbo.
  5. driver1
    driver1 Senior Member
    cant be very good because otherwise blowoff valves would not have a real purpose. I mean isnt that what they are for is to stop boost from heading back to the turbo when the throttlebody plate closes???
  6. pissedoffsol
    no- different concept. the bov is to prevent the turbo form having to stop/go backwards from the pressure surge back. this is going scross the seals.
  7. driver1
