boost or n/a
Discussion in 'Civic and del Sol - EG and EK' started by unlikelyhero, Oct 23, 2006.
  1. unlikelyhero
    unlikelyhero New Member
    Just want some opinions on my swap. whether to go boosted GSR or all motor Type R. Im leaning towards all motor, because this is going to be my commute car to work also. but im still indecisive.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well i say all motor
  3. greygoose
    greygoose Junior Member
    The next question is are going to drag race the car, autocross, or just want some more pep in your cars step? But all motor is fun just expensive
  4. MoSeS
    MoSeS New Member
    All Motor All The Way!!!!!!!!!!!!!!!!!!!!!!!!!!!
  5. H-Ridah
    H-Ridah New Member
    Curaçao
    Since I’ve seen the risks involved with forced induction I would advise you to go all motor. Plus no-one will know you're fast until you push down the pedal. Go with the type r swap dude.
  6. zex_cool
    zex_cool THE killer
    Boise, ID
    wtf N/A ?? who does that ??
    boost that shit ! !
  7. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    I think this is the kid that needs to hide everything from his parents, NA is prolly the best bet for him :)
  8. NightCat
    NightCat New Member
    sorry for bump..
    however...depending on what your stock engine is, and what you want out of your car, I'd actually say a blend.
    do some engine mods such as..piston heads, piston rings, and exhaust manifold ( if the kit doesn't come with one ) also an intercooler is reccomended, along with a boost timer as not to screw up your engine.
    however..a turbo isn't a beginner upgrade.
    if you want to put a turbo on, I'd do some engine, clutch and exhaust work first.
    Engine, i already said. Some piston work and air intake work. as for clutch, I see a turbo like Nitrous, you're putting more strain and tq on your clutch so I'd replace it with even just a stage 1 from ACT or clutchmaster or somethin. then exhaust..hello!!! it's a turbo, really should run a better exhaust if you want to get anywhere above 7-8 PSI.
    EDIT: I forgot to add, a new intake manifold would probablly be good too.
  9. CITY16
    CITY16 New Member
