boost sputter @ high boost
Discussion in 'Forced Induction' started by b16stalyun, Jan 3, 2009.
  1. b16stalyun
    b16stalyun New Member
    NC
    question, 2nd gear im at 13 lbs with creep up to 15. 3,4,5 gear i get a heavy sputter when i hit full boost. it does not do it in 2nd gear. only 3rd+ when i hit full boost. i thought i was hitting boost cut because of the boost creep. my boost cut is at 22.9lbs. I have a Motorola 2.5bar map sensor. which should be good to 35lbs. (1bar=14lbs) if im correct. so i lowered the boost in 3rd+ to 16.5lbs with a creep to about 19/20lbs depending on temp. it is still breaking up and not going near 22.9lbs.
    what could be the problem? the weather is about 20degrees-40degrees outside.
    plugs?
    wires?
    weather?
    tune?
  2. austin20110
    austin20110 New Member
    Northern Va
    fuel
  3. Briansol
    keep in mind, at sea level, you're already AT one bar for the atmosphere... so, a 2.5 bar sensor gives you ~ 1.5 bar of boost to play with, or about 22psi.
    but, breaking up sounds like you need more fuel and a better tune to compensate for the different burn of fuel in winter vs summer.
  4. 99sidude
    Ohio
    Agreed. My car runs like ass when it gets really cold out. I had to richen it up a little to compensate for it.
  5. b16stalyun
    NC
    update. i ran my car today. it was 65 degrees outside still had the sputter.
    in 2nd gear my a/f is about 11.5~
    in 3rd,4th at times it goes down to 10's
  6. Briansol
    10s is way to rich. lean it out a little
  7. b16stalyun
    NC
    update. the boost sputter was due to spark plugs. changed em out, re-gaped em and they work fine
