Boost up a H22 with NOS
Discussion in 'Forced Induction' started by FastRCars, Jun 7, 2005.
  1. FastRCars
    FastRCars Member
    The whole engine is bone stock , exept 4 some exterior simple bolt ons.
    What is possible to charge safetly with it?
    25Hp? 50Hp? 75Hp?
    I heard something about the crank not want to play with any higher outputs than "stock" power..
    So if anyone of u tried it ..pls give me some advice..
    And about engine managment when running NOS? whats necasary to change?..(sorry for my bad spelling) :imstupid:
  2. nismogod
    nismogod Senior Member
    Deltona, FL
    you mean NOS the brand name right? or are you referancing nitrous.
    jdm or usdm spec? you can run a 100 shot, if you want, but a 75 would require less effort of tuning. as far as engine management, just get a MSD timing retard. retard it 2 degrees if you are goin 75 shot.
  3. FastRCars
    FastRCars Member
    I was referancing Nitrous..im talking about a JDM H22 its down to a Civic EG -94
    MSD timing retard? anyone got some links?
  4. FastRCars
    FastRCars Member
    More suggestions?
  5. reckedracing
    reckedracing TTIWWOP VIP
    NY
    google.com owns you...
    and i would advise a wet kit over a dry kit...
    and maybe start with a 55 shot... that should give you a nice warm tingly feeling in your pants...
  6. reckedracing
    NY
    why is this in forced induction?
  7. nismogod
    Deltona, FL
    nitrous = forced induction
    55 is a good starting point if you've never used nitrous. wet > dry by far. i would suggest not going over a 75 tho, since you dont have much experience with it.
  8. reckedracing
    NY
    since when does nitrous = forced induction...?
  9. endlesszeal
    endlesszeal Senior Member
    cramming more O2 by other means instead of massive inhalation via intake or ITB.
  10. endlesszeal
    doesnt make sense. disregard. i think because force induction is jamming more air into the engine with assistance. like turbos aid by compressing and same as superchargers. nitrous does the thing except not compressing by delivering it and breaking down.
    ramble ramble.. whatever its worth.
  11. FastRCars
    FastRCars Member
    Well..if its n wrong place..some one could move it..or..not..what ever
    I got this "used" NX Stage 1 Nitrous with 50 Hp Nozzle...i think it is a dry system right? , it mixture "nos" & gas before the intake manifold.
  12. nismogod
    Deltona, FL
    the location that the nitrous comes in, is based on where you put it. and if it sprays a mixture, thats a wet system. a dry system sprays nitrous only, and increases the fuel pressure so the injectors/fuel system compensate
  13. mozzandherb
    mozzandherb Senior Member
    Why do you suggest a wet kit? I was suggested a dry kit for the H22a for nitrous by Zex, less problems they say.
