boosted gsr
Discussion in 'Forced Induction' started by gsrhatch92, Jan 20, 2011.
  1. gsrhatch92
    gsrhatch92 New Member
    hey guys i have done plenty of research and and cant find anything anything refering back to it.....
    i want to add a t67 turbo to my gsr hatch and cant find what parts i need for it.... im going to p&p the head. new cams and every thing. havent figured out brand yet... as far as the block do i have to build that up as well... i want a strong healthy boosted gsr.... im going to guess i would have to sleeve the block...
    thank for any advice
  2. SlushboxTeggy
    NJ to MA to CA
    Where have you searched? As far as Hondas go, this is a basic and extremely common occurrence.
  3. Matts96HB
    Matts96HB . Moderator VIP
    where'd you come up with t67?
    you need to set a power goal first. then start researching
  4. gsrhatch92
    my goal is around 500 - 600... low boost weekend car and then drag strip... ik i have to upgrade the susp, brakes, axels
  5. Matts96HB
    A lot more than that! you'll need a different ecu, fuel pump injectors, mounts, etc.. do a search. The info is out there on 500-600 whp setups
  6. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    a 500+ whp setup is not to be taken lightly. it wont be cheap to do it right. you need to upgrade nearly everything.
  7. SlushboxTeggy
    NJ to MA to CA
    If you want 500-600 HP in an import with a stock or mostly stock bottom end, you're looking at the wrong brand.
    Build the motor. Turbo it to about 250-300. Get use to it. Swap the turbo.
  8. newb
    newb phresh VIP
    Backwoods Northwest
    Ya, sleeves are a good place to start. Then after that, you just need to replace every other part in the powertrain.
