boostin an ls?
Discussion in 'Forced Induction' started by doezitmater, Sep 2, 2007.
  1. doezitmater
    doezitmater New Member
    i just got my hands on a 1994 integra, i am going to build the non vtech motor for boost. I would like to run around 15 pounds .. i was curious to know what kind of cams to put in it. and i was thinken about using eagle rods and wiseco pistons with arp head bolts but im not sure if thats a good and strong way to go .. and i also dont know what kind of head gasket to use .. any suggestions? .. p.s i know i posted this in the wrong section the first time .... my bad
  2. formby
    formby learning in progress
    15lbs?
    huh
    what turbo?
    lbs mean nothing
    ands its vtec not the phone vtech..
    read up
  3. c97x
    c97x sorry boss, its turbo
    dont put aftermarket cams in, if your boosting 15lbs on a decent sized turbo. lots of boost doesnt like the overlap period in a engine, and bigger cams increase the overlap and duration i believe, by the way that ls motor should be able to take 300hp on stock internals
  4. formby
    they do sell after market turbo cams you know
  5. eg6sir
    he probably doesnt.. he was just asking how to remove his rear seat from this hatch
  6. c97x
    i never removed a rear seat so i just asked how, and sorry i forgot about turbo cams, i just think there not needed
    if he's running a turbo with lots of backpressure it could make hot air flow back into the engine just my 2 cents
