boostin...how much
Discussion in 'Integra' started by 96gsr_slut, Apr 3, 2007.
  1. 96gsr_slut
    96gsr_slut New Member
    i have 96 gsr with some mods...lookin for turbo and wondering how much i can boost on stock internals and wanting to know what to upgrade to boost around 15-20 psi
  2. myah
    myah Neu Impact Performance
    ks
    sleeved block and new pistons i would do that b4 i put boost on my you'll need to run either hondata and neptune ecu but you'll blow your blow if your gonna go 15-20 lbs. of boost but i would atleast put new piston in to lower the compression
  3. welfare
    welfare Ancient Member
    New York
    to answer your first question, you can run about 6-8psi with a piggyback fmu or afc. with a good tune prolly 10-12, but that's prolly ppushing it.
    I run my jrsc at 6psi with just an fmu and a boost timing controller, i have had no problems in over 8 months, turbo is a different beast over s/c tho.
  4. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    get yourself pistons, rods, fuel upgrade and boost up to 20psi with a good tune.
    anything over 20psi i recommend you get your block sleeved.^_^
  5. welfare
    New York
    I agree
  6. myah
    ks
    i really don't agree my friend had piston and rods and a good tune running 15 bls. of boost and blew his block don't risk it cause your going to pay for in the long run if you want something reliable i would go with a sleeved block and pistons
  7. get_nick
    Washington State
    the only time you will blow your engine is if you have a bad tune.
    different turbos put out different power at different psi. pick a good turbo then go from there.
  8. myah
    ks
    it's going to be whatever you want if you want more advice i would ask kenny tran at Jotech Motor Sports - || Home Page || and see what he tells you or go to T1 Race Development and ask then tony palo what to do one of the best tuners in the country cause i guaranty they will tell you to sleeve the block
  9. Estorvito
    Orlando FL
