S Slammed90Lude Senior Member Aug 28, 2003 #3 what would the best way for proper fueling be? hondata? or is there a slightly less expensive route- could I use a APEXI fuel controller?
T Tonyd0821 Banned Sep 3, 2003 #6 Originally posted by Loco Honkey@Aug 28 2003, 10:32 PM 10 PSI with proper fueling. Click to expand... The answer to ALL of your turbo D series questions.... and i agree with loco honkey to a point. id go as high as 12psi (mitsu 15g) on a "stock" unbuilt engine. but 10 is a relatively safe #. Correct me if im wrong, but the blue box can only sustain up to 10psi before a CEL is thrown....
P posol RETIRED Sep 4, 2003 #7 any honda for that matter. 10.65 psi give or take a couple points based on your local elevation is where the oem map sensor tops out.
