Boosting With Stock Electronics?
Discussion in 'Forced Induction' started by Kinked_Chrome, Jan 15, 2003.
  1. Kinked_Chrome
    Kinked_Chrome Junior Member
    Good 'Ol Idaho
    My buddy and I swapped a b16 into his 4th gen Civic hatch with a few bolt ons. Fun car, good performance, but we're ready for more. We have a nice turbo setup planned out. We going to use a T3, and want to run about 10psi. Is this modest enough for daily driving? The only thing we don't know about is the electronics. Is the stock MAP and ECM going to recognize 10-15psi? :unsure: Or do we have to make for modifications. This is relativaly low budget and we want to avoid moving to a stand alone FI system.
  2. pissedoffsol
    stock ECU will not read more than 2 psi without throwing codes.
    honda map sensors wont read above 11 psi with out throwing codes.
    you need both a missing link and a GM 2- or 3-bar map sensor.
    OR
    aem/hondata and a 2- or 3-bar map
    and i recommend the aem you run anyway.
  3. redtao
    redtao Member
    :spin: :spin: Hey pissedoff that GM 2- or 3-bar map sensor your talking about, what are the disadvantages if there are some and how do we find the one that fits our civic. I have a 97 delsol dohc.
  4. Kinked_Chrome
    Good 'Ol Idaho
    Ok, so a new map is in order. What do you mean 'missing link', and is the hondata an ECU mod?
  5. sisteve
    sisteve Guest
    a hondata is a standalone ecu system (www.hondata.com) its fully customizable, works basically the same way an aem does.
    The 3-bar map sensor from GM will fit any year honda 88-00, should just bolt on. The advantages of it are it will read up to 3 Bars (~44.1 psi) while the stock honda sensor can only read up to 11-12psi
    hth
  6. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    what do you mean a GM map sensor.... i'm confuesd aare you talking about GM As in General motors?????? what the fuck would they need a 3 bar map sensor for? or goes GM stand for somthing else
  7. sisteve
    sisteve Guest
    yes, gm as in general motors. I'm assuming they make them because most of their parts are interchangeable just like all other companies, and well, some cars came boosted from the factory (GN, T-Type, Typhoon, Syclone etc etc) and needed a higher map sensor to accomodate for boost heads :)
    and most people dont know, but gm and honda go back aways...honda actually sold some engines to gm, and vice versa...so if you see a 8 cyl honda coming out soon...its a gm engine :)
  8. pissedoffsol
    yup- its an OEM chevy/buick map sensor... aka General Motors
    a missing link simple tricks the ecu into reading that its not getting boost so it wont throw a code- but if you go over 11psi, the map sensor won't know what the fuck to do, so it throws a code anyway, thus putting you in closed loop and crappy performance
  9. Kinked_Chrome
    Good 'Ol Idaho
    Ok, I checked out hondata. It's a pretty trick system, but I don't think we need for our application. This is a mild setup that we want to make streetable and reliable. I have a GM MAP around actually (thought it went out on my LT1 260z, see my needed to be updated website), so for the missing link, do I need a resistor or relay, or simply cut the wire? and will the computer know to give it more fuel with just the MAP and the missing link?
  10. prawjEKt Cx
    upstate NY
    god a gm motor in a honda...... :puke:
