whats the stock bore size of a ls? plus the .25 os pr3's? Do I just add? stock would be I think 81mm bore so 81.25? I just need to know so I can order the GE lsvtec conversion kit because its comes in differnt sizes. Basically my setup is a ls block with .25 os pr3's. Which kit would need to be ordered?
ok iam confused now, I bought .25 oversized pistons from honda dealer. I work there so I get good discounts. Honda doesn't sell .50 os pistons. They don't even reconmend going .30 over. I sent my block to engine lab and gave them my pistons and ls block. They fitted the pistons to factory tolerances. Which I would think would be 81.25mm bore if its a .25 over pistons. Ive already test fited on of the pistons and everything is well.
81.25mm is the standard B18 oversize according to my Integra service manual. The allowable bore range is 81.25 to 81.27mm, with a maximum taper of 0.05mm between the top (6mm below deck) and bottom (6mm above bottom of sleeve).
