Bore
Discussion in 'Engine Building' started by punx04, Jan 9, 2003.
  1. punx04
    punx04 Member
    san diego
    i just want people's opinion on a perfect bore size for a 1.6L all motor high compression engine?
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    are you saying that you want to bore out the 1.6L block? is it a b series or d series?? or do you want to know what compression piston to run with stock bore?
  3. pissedoffsol
    all motor or Forced induction is a factor as well
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    See quoted
  5. punx04
    punx04 Member
    san diego
    d series and like i said high compression
  6. pills_PMD
    New Albany, OH
    so you want to bore out the block? .... dont.
  7. phunky.buddha
    Dallas / Fort Worth, TX
    You might get up to 1720cc if you can bore out to 78mm... but you'll have paper thin cylinder walls, and you probably can't go that high anyway.
    Bore / stroke (D16Z6) / displacement:
    75mm / 90mm / 1590cc
    75.5mm / 90mm / 1612c
    76mm / 90mm / 1633cc
    77mm / 90mm / 1676cc
    78mm / 90mm / 1720cc
    79mm / 90mm / 1765cc
    80mm / 90mm / 1810cc
    I guess you could do it, but I doubt you'd be able to get to the higher bores...
  8. punx04
    punx04 Member
    san diego
    is boring it out even worth it? like will it give me that much tq and hp that it's worth cracking my cylinder head? and if u were forced to use this engine, which would u go with or wut would u do to the bottom end, including dimensions
