boring my B16a1
Discussion in 'Engine Building' started by gunz2165, Aug 2, 2004.
  1. gunz2165
    gunz2165 Member
    connecticut
    i was told that i can not bore out the block to my B16a1 from a 1.6 to a 1.8 which it would be bored .020. is this true or can it be done? please let me know asap.
  2. beerbongskickass
    beerbongskickass Senior Member
    Longview WA
    Boring your b16 .020 will make it 81.5mm (stock is 81mm). If your rebuilding your motor it's a good idea to do this to make sure the cylinders are round. You will need to get .020 oversize pistons also. If your planning to boost on the stock sleeves do not bore it out more than 81.5mm.
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    To answer your question you would need to bore the engine out 3mm (from 81mm to 84mm) to make ~1.8L. I don't think that the stock sleeves can take that much overbore.
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    84mm on b16 is 1.7L, the other 100cc has to be stroked.
  5. calvin
    calvin Senior Member
    NETHERLANDS
    Normally 81.5 mm is the largest oversize piston i have seen for the b16a2. I have a set of New SRP pistons 81.5 mm
  6. khai_tuan_nguyen
    khai_tuan_nguyen Senior Member
    I thought 84mm is 2.0 like the crv? I guess the stroke is different. So what is the Liter size of an actual b20 with b16 head?
  7. StyleTEG
    StyleTEG Senior Member
    I don't see why not, the B16 has very little side-loading.
    B20 has much worse side loading and 84mm bore. (but lets not get into the b20 may have different sleeves again ;) )
  8. B16
    B16 Super Moderator VIP
    yay area, CA
    uhh... 2.0L the head has no effect in the displacement of a motor. its only bore and stroke.
  9. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    why not just buy an ls or gsr bottom
  10. shaneb
    shaneb Member
    any one know a good site to get 82 mm honda pistons like p30 or pr3's ...( 40 over)
  11. calvin
    NETHERLANDS
    b20 with ITR crank 1930cc
    b20 with B16 crank 17... cc(good RS ratio for boost)
    b20 with b17 crank 17.. cc(best RS ratio for boost)
  12. calvin
    NETHERLANDS
    I will host some of the old CRVtec site on my website lot of usefull b20 hybrid info
  13. 97CTR
    97CTR Senior Member
    The largest you will want to go is 82mm on stock sleeves, if you want to crack sleeves then go ahead and bore it out more. And yes the b20 does have different sleeves meant to be 84mm, as well as a slightly diffrent design.
  14. StyleTEG
    I have never seen any evideance of this, where did you get this information?
    Again, all the stock sleeves are cast iron push ins. They are all open deck. The outer rings are all alluminum.
    How is the design different, other than the sleeves are cast that way or opened up to that much?
    Either way it shouldn't matter, as the material is the same, and the thickness is the same.
  15. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Uhhh, I don't think honda made a .040in oversized piston, because the maximum allowable overbore on a honda's stock sleeves is .020in over, as per the factory (helms). So go with some aftermarket pistons.
  16. MikeBergy
    Central Coast, CALI
  17. MikeBergy
    Central Coast, CALI
    Is this your own opinion, or do you have some good evidence of this? Please post links, as I'd like to see them.
  18. K2e2vin
    Raleigh, NC
    btw wouldnt a b17 crank in a b20 be more like 1800cc?
  19. B16
    yay area, CA
  20. B16
    yay area, CA
    for some reason i thought the B20 had different sleeves. so you can bore out any B block to 84mm on stock sleeves and it will be just like the sleeves in the B20??
