boring my B16a1
Discussion in 'Engine Building' started by b16a1dohc, Jun 14, 2014.
  1. b16a1dohc
    b16a1dohc New Member
    Hi guys! Im rebuilding my b16a1 dohc vtec engine.. had the head gasflowd ordered a set of branches and spitronics fuel management chip..im thinking of getting 0.30mm pistons.as im going to have the cylinders cleaned and bored. ..
    Any advice guys? Thanks
  2. b16a1dohc
  3. b16a1dohc
  4. b16a1dohc
  5. phunky.buddha
    Dallas / Fort Worth, TX
    Holy crap, resurrected a thread that was almost 10 years dormant...
    Have the machine shop check and see how much absolutely has to be bored to clean up the cylinders if at all, then decide on your piston size. The amount of displacement you gain from a half millimeter really isn't worth the expense or strength loss, plus finding pistons might be a bit harder, plus you might kill the engine and need to bore on another cleanup- bore now and you'll have less to work with later.
  6. Briansol
    81.25 is standard over-bore. why .30 over?
