Quoted post[/post]]
you can get a B20 long block for 650 from hmotors.
Quoted post[/post]]
itd be easier to have a 85 mm bore. if you are really looking high displacement.
it wont require resleeving and a new block is cheaper than the entire sleeving process. you put a GSR head on the B20 it can make well over 200 HP. a simple turbo kit will easily put you at the 300 mark, even with stock pistons and rods.
CRVTEC is seriously an under utilized design IMO, but hey, what do i know?
Quoted post[/post]]
no, no, no.if you want anyhting reliable donot use a b20 block. and DO NOT BORE TO 85MM!!!
Quoted post[/post]]
i dont thin those have a open deck or anything. too much money imo
Quoted post[/post]]
hence sleeving and block guard...i unno, just bouncing off ideas, not criticizing
Quoted post[/post]]
84 is stock but it has a bigger stroke to get a 2ltr.
Quoted post[/post]]
there is no reason to NOT go with an 84.5mm. the dart still exceeds your needs, but the torque is always a good thing. .5mm over is not a big deal, and then your pistons become JE shelf stock.
