Bottom end
4doorEG
I need help known a few things ab a gsr bottom end. I am new to building hondas and I need some help or advice when putting it together. I have done some research and I need to know the ring gap and wall clearance for cp piston with stock bore and I need to know torque specs for the main studs and head studs as well please give me some advice u can reach me at iankepple@ymail.com thanks a lot
Helms manual is your friend.
Wall clearance should be specific to the piston you have; you need to contact the manufacture for that and ring gap.
