bought 00 si harness and ecu and 1 plug doesnt fit
Discussion in 'ECU's, Electronics, and Tuning' started by g24jr, May 25, 2005.
  1. g24jr
    g24jr Member
    MCMINNVILLE, OR
    i bought a 00 si ecu and a 00 wiring harness and the green ecu plug doesnt fit into the ecu and (is it suppose to be filled with only half the wires) someone who has a stock 00 si harness please send me pics or something and tell me how many wires their harness has on each ecu plug
    thanks
  2. boomslang
    boomslang New Member
    The green plug doesn't go into the ecu.
    Only plugs A, B, and C should be present in an '00 Si harness.
  3. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    Is it a small green plug its probably the ecu service plug. If its a large green plug its for an automatic transmission. (which means that you do not have a 00 si harness, because 99-00 si did not ever come with auto trannys)
  4. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    i have a 00 civic Si harness and it has a bigger green plug and it doesnt plug into the ecu either, no it is not auto.
    My guess was that maybe it plugs into the car somewhere, and another plug comes down into the ecu.
  5. JKOBD.com
    JKOBD.com Wiring Guru
    Engineer at the Source
    You are correct. It is not an auto only plug, it is a junction plug that goes to different underdash components and the fuse panel.
    Confirm that you received both the OBD2b harnesses.
  6. VTECin5th
    Phoenix Az
    :huh:
    what?
  7. noobvang
    noobvang Senior Member
    Twincities, MN
    What kind of car do you have???
    This would help us help you more....
