time to clear some stuff up, lol
90-93 integras all had cable trannies
90-91 have a smaller input shaft
92-93 had a larger input shaft (same size as 94+)
90-93 all has the same number of splines, 92-93 just has a bigger shaft (something like 1mm bigger or something)
when you lower ANY car you loose suspension travel. CRX's moreso because the front shocks are pretty short. using the accord shocks (which are even shorter then the crx's) will help you equal out what you lost. i dont know how to explain it without pictures. you can also do things like extended top hats. i have the ground control top hats on my car and i gained something like an inch of suspension travel (and they look cool )
