Bouncing Idle when cold - Not MAP/PCV/Cleaned IACV/FITV
wanderinman
When the car first starts up the idle will bounce from 1500 to 2500 with a pretty regular beat. The guy I bought it from said it was a bad MAP sensor. Just want to make sure that was a legit reason for this problem before I spend the money on a new one.
Quoted post[/post]]
Possible/more likely the IACV... no check engine lights?
Could be the MAP, also could be the front O2 sensor.
When I started my car after the end of the project it did the same, I had the O2 wiring a lil off. After I fixed that the problem went away. Maybe your O2 is bad, how old is it?
The car has 232K on it. Its a stock motor/tranny no swaps. Only mods under the hood are a short ram intake. And no, the check engine light wasn't on.
I doubt it is the O2, especially since the ecu doesn't look for the O2 sensor until it switches to closed loop mode. I'd say either the EACV/IACV or the fast idle thermo valve (FITV) both of wich are located next to the throttle body. Clean those bad boys out with some wd40 and some compressed air, and then check and see if you still have your idle problems. It could be a MAP sensor, but if you are only getting these problems when the engine is cold, it's probably not the MAP sensor.
When I had no front O2, the car would do this even before it warmed up. Thats why I thought the O2 could be an issue, it does have 220K on it too.
for what car? I see in your sig you have a 92 accord, which would be obd1, and a bit different than his 91 accord, which would be obd0. I don't know, I guess anything is possible. I had my o2 sensor completely disconnected, and nothing happened until after the car warmed up and went into closed loop.
Quoted post[/post]]
Some 91s are obd1, we just got one from 2/91 that is obd1 :)
I would just pull the IACV and clean it up, and clean the IATS too.
Quoted post[/post]]
Quoted post[/post]]
Well, shoot. I guess I got robbed of a better EMS... I thought Honda as a company made the switch to obd1 in 1992. Learn something new everyday.
Thats my bad as well, I assumed since the 90-93 are the same looking that the electronics would be the same. I learned something new too :)
Quoted post[/post]]
Ok, here's the newest info I got....
No check engine lights when the car is usually running, in fact I've never seen one except as described below.
Cleaned the IACV and the FITV both out. Engine still had a bouncing idle. It also does it when its already warmed up, not just cold. When I completely unhooked the IACV with the engine running the idle still bounced, just much less pronounced. 1000-1200 rapidly w/ a check engine light (duh) instead of 1500-2500 slower. Also the FITV is working as advertised, pulls air when the engine is cold, and stops when its warm. I guess I will give the o2 a shot, it probably needs to be done anyway.
Quickly though, I did find a bit of engine oil in the IACV, nothing major, a few drops mostly, but any ideas on that? I guess it came in through the PCV valve and ran down the inside of the intake manifold.
I'll post later after I replace the o2, hopefully its cheap like my Troopers was (the troopers was $6.95).
Holy crap parts were expensive...
80ish for an o2, 178.99 for the IACV, and 98.99 for the FITV.
Anybody got spare parts laying around they wanna sell me?
What about the PCV valve? I know it usually makes the car smoke if its bad, but it is a vacuum controlled lil device. It could be stuck partially open and cause that fluctuation. They're only like $3 too.
I'll check that, it would account for the oil in the intake manifold. However, the engine is still burning clean as a whistle, 233K miles and nothing out the exhaust pipe.
^At least it was cheap. Def a stumper you got there.
Yea, its killing me. I am going to replace the MAP sensor as soon as I get around to finding one thats not an arm and a leg. They have them like crazy on EBay. Hopefully getting one for 9.99 instead of $248 or whatever Autozone wanted.
