BOV question
Discussion in 'Civic and CRX - EF' started by 8ballsin, Sep 25, 2008.
  1. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    i have a question i had a hks ssqv bov on my D15B2 before i blew the motor and i was wondering why the bov did not sound when reved up from idel is there a reason for this im new to forced induction all i know is that it sounds sexy as hell when driving and will i here it from idel when i drop in my D16Z6
  2. cjvictoria
    cjvictoria New Member
    N. Chuck, SC
    i dunno man the only thing i could think of is that maybe the d15 didnt generate enough boost to blow anything off? i have no idea for sure:confused:
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    its normal i know that it will really only do it good under load, but i forget why its like that, but its normal
  4. cjvictoria
    N. Chuck, SC
    me and ahhhvtec must be constantly clicking that 'unread post'
  5. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    load on the motor is the only way to build up enough boost pressure to actually blow off...
    The only reason you see cars that come from the factory turbo'd able to blow off from just reving up is because you are hearing the diverter valve shoot what little boost was made, back into the intake manifold.
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    or there was too heavy of a spring in the BOV causing there to not be enough pressure to open it?
  7. B16RacerN2NR
    Moving back West...
    and you need load on the motor to build any amount of boost... I don't care if an adjustable blow off valve had cotton balls in it, you still need boost to blow off.
