sup everyone, i have a 94 honda civic. i'm having trouble with the brakes. after searching through the forums, i have found that it to be either my brake master cylinder or brake booster. according to one of the forums, if my car is off, and i pump pump pump the brakes, if it gets hard then my master cylinder is good(and it does get hard when my engine is off). but when i start up my engine, the brakes go down more than 1.5 inches in all the way to the floor. i have no leaks in fluid. is this test accurate in determining the problem to be the brake booster since the breaks get hard after being pumped when my car is off. thanks.
