the "feel" is much better, the brakes feel alot more solid and you definatly feel more confidence in your car, crxs are notoriously underbraked and i dont care what you argue about drums, discs are better drums are old and outdated technology and not worth the hastle, the disks are your best bet, the swap is easy, i used 93 teg rear setup with the brake lines prop valve and ebrake cable like i said before, i spent less than 200 and they came out awesome, make sure you change the rotors and pads while your at it and clean up the arms and give them some paint, why do it half assed right? DO also beef up your front brakes, they do take the brunt of the braking get a good set of crossdrilled rotors, i lean away from the slotted kind cuz they eat brakes pads weekly it seems haah, the drilled do the same thing but it takes a noticeable bit longer time for it to happen. You can use teg front brakes also if you want cuz they have better calipers and bigger rotors just make sure your wheels can fit the rotors behind them.
email me if you have any other ?'s
