i need to add brake fluid to my car (i got an ABS system on my 1990 Integra GS)and was wondering if i am going to have to bleed the lines after filling the ABS brake fluid reservoir. thanks all!!
if the level in the reservoir is just low, you'll be fine. if there's no fluid in the reservoir, you probably have air in the lines and will need to bleed. You might even need to bench bleed the master cylinder.
