Brake Rotor
Discussion in 'HYBRID -> EG-EK / DC' started by markie, Mar 14, 2003.
  1. markie
    markie Senior Member
    what do i need to install a brake rotor
  2. GSRCRXsi
    MD
    your hands, a socket wrench set, and a screwdriver. its simple man, just unhook your caliper, unscrew the rotor from the hub assembly, put on new rotor, screw it back on, compress your brake pistons in the calipers, and put the pads and caliper back on, screw everything on tight and you should be good to go.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    www.helminc.com #1 upgrade and will tell you how to do all kinds of neat things step by step.
