Alright, so both my brother and I have Del Sols. It comes in handy when we are trying to compare something like an assembly, a noise, or in this case pedal travel. My brakes have been bled the same way as his, (push pedal, open valve, release pedal, close valve), on all 4 wheels, but my pedal travel goes in like 3 inches before any braking occurs. His on the other hand, almost full braking occurs at 2 inches. (Noticable braking at 1 inch)
So my question I guess is does the procedue for bleeding the brakes sound right? If so, then is there anywhere else in the line that could have air that I don't know about bleeding?
Finally, my car is a 1994 with stock lines, and his a 93 with stock lines. Is it possible that my lines just need replacement?
Ideas?
Ideas?
